By design or bug?
Measured an autofeature (cylinder in my case).
F9 the autofeature and hit OK (do not edit anything).
Note the measured values has been overwritten with the THEOS/TARGS (just like you created a new feature).
Expected behaviour: Nothing should be overwritten, if anything should be overwritten, it is the changes I had made (nothing, that is).
Hitting "Cancel" does not change the MEAS.
Additional bug:
Change the THEOS for the autofeature in the edit window, and answer yes to the update target values.
Note that the measured values did not change in the edit window, but they have changed "behind the scenes" for the feature.
I noticed this as my TP for the cylinder was 0.
So, it has the same behaviour as the first issue, but without the updated edit window code.
I believe we have had this issue in an earlier version...
neil.challinor
Additional bug:
neil.challinor
