Is there a way to simply write and update code in Pc-dmis without the code beneath it changing?
Turn It Off!
Originally posted by keego View PostIs there a way to simply write and update code in Pc-dmis without the code beneath it changing?
You want to change an alignment without all the code
further down in the program changing too? When it asks
if you want to update/change tell it NO. This applies to
changes made in features and dimensions as well. HTH
(Hope This Helps) If not, please post an example.
P.S. The demon does not like it if you fool with it's alignments
after there is code down below. It tends to crash, so save a
backup copy first.
by David WedelI simply run a part and with in running the part i measure the holes and at the end of the part program I recall my manual aligment and set my origin...
06-03-2014, 01:29 PM -
by TinyfxdsHow do you insert code into a post? I've noticed on quite a few threads that people will add the code from their program and it inserts it into it's...
02-20-2015, 05:20 PM -
by RondogHow do you post code or script files to this forum?
Do you need something external (i.e. drop box, rapid share, etc) to do this?-
Channel: PC-DMIS Code Samples
03-02-2013, 09:34 AM -
by giantslayerSo I made a simple program never intending to use it often, I was a bit careless. I ended up making a more complicated program out of it because of a...
09-25-2015, 03:49 PM -
by PATRICK PHi All, I'm using a cone for the frist time, and in a interative alignment to boot!
I did use part=cad, however after reading some posts on this...-
07-16-2008, 10:13 AM -
