Is there a way to make the true position check box stay unchecked for size? Whenever I uncheck the box it still reports out. Is there some way I can stop this from happening. See attached. Thanks.
Uncheck box in Xact Measure
That's not XactMeasure, it's the Geometric Tolerance command. If there is a modifier (MMC/LMC) then you can't disable size because it is needed for the bonus calculation.Neil Challinor
PC-DMIS Product Owner
E: [email protected]com
- Likes 2
by MikeFon my legacy position report I don't see the feature MMC bonus, how can I turn this back on?...
09-17-2020, 11:21 AM -
by Spencer_23Is there any way that you can just show positions using exact measure and not have it show the Diameters?
05-04-2013, 12:33 AM -
by jozeyWhen dimensioning true position in Xact measure, do you guys input the diameter size in the feature control frame.... example .010 | A | B[.505]...
10-30-2019, 11:24 AM -
by JamesMuz5689When reporting a true position, should the Feature MMC bonus and Datum LMC bonus be added together, to give a an overall bonus.
Pc-Dmis defaults...-
09-06-2018, 04:47 AM -
by oriental_sunHey everyone a quick question? I am using 4.2 and for whatever reason when i check these cylinders and do true positions the ID is getting bonus on MMC...
06-24-2011, 08:14 AM -
