Hello All. I have a CAD model assembly that has something in the way of a feature I need to measure. Is there a way to convert the offending object - so I can hide it? Thanks in advance.
Remove CAD elements from CAD model.
Not quite what you are looking for but still useful. If parts of the fixture and/ or assembly are in the way of selecting or seeing a point on cad, it is possible to hide the offending Cad object.
Edit/ Graphics Display Window/ Cad Assembly. Should show a tree of all the objects in the Assembly. May need to click on the + sign on the main Cad assembly. Click on the item that is in the way and it will disappear. Reverse the process when you want the object back. You can also transform the objects to get them moved where they belong. Right click on the object name in the tree and select Transform.
Similar to this is to put the offending cad into a cad layer that can be turned on/off as deleting as stated above is not always desired.
Edit/Graphics Display Window/Cad Levels. Under "Editing", click "Create" to create a new layer. Select the new layer, start selecting cad and select "Add" under
Cad Elements. Now you can turn on and off. Keep adding or you have the ability to subtract in case you clicked on a surface you need. I do this for hardware that wasn't layered in the cad.
You can also create a section cut of the cad if your goal is solely to increase visibility when programming.
The tool to section CAD is buried under Edit: Graphic Display Window: Clip Planes
you can also use clip planes to produce 2d features from the CAD.
I have some Tremendously large CAD models and will have 4 or 5 programs for that CAD. How can one associate multiple programs to one CAD model in 4.2...
04-02-2008, 01:23 PM -
by WindsorEdHello again,
How would I go about deleting features off of cad model that is imported into PC DIMIS 2020 R1? There is a clip that I would...-
Channel: PC-DMIS Portable
03-21-2020, 06:29 PM -
Hi,
I have a CAD with components. But components not I need to measure. Component and CAD is one block. Single deleting elements is time-consuming...-
05-29-2016, 02:05 PM -
by UnderspecI now have two CAD models in graphics window. What's going wrong?
07-12-2007, 03:42 PM -
by AggieGradCan someone tell me how to do this? I have a program that has a total of 4 different CAD models. 3 for custom built fixtures, and 1 part model. We...
12-11-2020, 10:04 PM -
