is 4.2 the cure for this 4.1 issue or am I just doing something stupid. The program looks good until I re-run it then the Y distances on the last two true positions changes. If you look at the Y distance in the distance measurement before the true position frame, the Y distance is correct but in the true position frame it has changed by about 60mm. see the attached before and after samples.
Is 4.2 the cure for this 4.1 issue
by Steven69I have a question. What is the difference between DMIS 4.1 and 4.2? Is it worth my time and energy to upgrade? What problems has 4.2 fixed? What problems...
08-28-2007, 09:28 PM -
by firehausAnybody heard on a release date for 4.2? The longer we are in 4.1, the more work arounds that have to be developed. If this keeps up much longer, thinking...
12-19-2006, 09:28 AM -
by ptedrumI'm currently using PC DMIS 4.1 (it's what came with the machine) and from everything I've heard 4.2 would be a step up so I'm looking for a bit of advice...
05-11-2007, 10:21 AM -
by jjewellI am running and programming a machine with ver 4.1 release version on it.
What a peice of crap version...anyway, should I bring them up...-
11-24-2007, 08:17 AM -
by TestedHas anyone else had this happen to them. I haven't noticed it before but, this morning I find that both my print out and my file do not match the edit...
08-03-2007, 10:42 AM -
