Is there a way to increase the spacing for the calibration locate portion of the cal routine?
If you answer, “YES the ball has moved”, you take one hit on top of the cal sphere, and then the software takes three hits. I would like to increase the spacing for these hits. After it measures its 3 pts it then procedes to measure the tip dia. The problem is that it starts to measure the shank (uh... no shank calib selected). Is there a trick to this that I'm missing?
It seems that in the rest of the metrology world we need 120° of arc to begin to measure a circle, But the Demon can do it with about 5°?!?!?
What gives?
What gives?
