Assignment question
  • Assignment question
    What is wrong with this assignment statement?
    Assign/V1 = Datum A.Y-.050
    It gives me invalid expression in the assign from dialog box. Datum A is a plane that I have leveled to in the Y axis. The expression value should be -.050. Could it be the space in the feature name? I am using version 3.7 MR3.
    Use NO spaces or special characters in your feature ID's, stick to letters and numbers to eliminate problems like this. Also, remember, if you use a feature ID in an assignment, if you later change the feature's ID, it will NOT update in the assignment.
      Maybe it doesnt like the blank in the feature name.
      Also, unless you leveled on the plane, the coordinates for a plane are worthless. If you leveled on the plane, then the axis it is leveled to is the only one valid.
        It's either that or try Assign/v1 = Datum_A.Y.Meas-.050
          Here is one I use. I stick with the PC-DMIS naming convention when I need to use them in variables.
          ASSIGN/V2 = ABS(F4.A.MEAS)/2
            I take it your feature name is Datum a
              While on the topic of assignment statements. I've run into inconsistant assignment statement result. In most programming languages I'm familier with, the sign of a value can be reversed by placing a negitive sign before the variable containing the value (example: V2 = -V1). This does not work in PCDMIS (v3.7). Rewrite the statement to V2 = (-1) * V1.
                Rewrite the statement to V2 = V1*-1
                Contura Calypso 5.4
