My 4.2 problem of the day
  • My 4.2 problem of the day
    The report should print a .pdf to my network drive (it did in 4.1) and now it doesn't in 4.2. Any ideas! The "Send Report output to" is checked and it is to file "FILE_NAME"
    C1 =COMMENT/INPUT,YES,'Order #'
    C3 =COMMENT/INPUT,YES,'Sample #'
    C2 =COMMENT/INPUT,YES,'Gauge'
    COMMENT/OPER,NO,Bolt part down at A2, A7, and B8
    ASSIGN/FILE_NAME = "M:\\DATA\Machine Check\\" + "80153-514_" + C1.INPUT + "_" + C3.INPUT + ".PDF"
    PCDMIS 2015.1
    Only thing I can think of is that if you have marked sets, you have to enable printing without any marked set enabled.
    I would also change it to the local drive just to see if it works that way. That will tell you if your network is working properly.
