When doing a scan, (linear open), is there a way to delete individual points from the scan and then it automatically recalculate the points for the new profile?
removing individual points
Tags: None
Originally posted by jkb_mcg View PostWhen doing a scan, (linear open), is there a way to delete individual points from the scan and then it automatically recalculate the points for the new profile?sigpic
Originally posted by JamesMannes View PostYeah, show all hits and look for the hit(s) you want to remove. Highlight and delete them. Now go to your profile dimension and "F9" it. Hit create and close. Should be updated. Let me guess outliers? That why I continued on into the 4+ land. More robustsure footed scanning can be had in 4+ land.
As already noted, you can just delete the hits (from the text of the program). The only trouble is to understand which are exactly the lines to delete... You may refer to T value if you want to delete hits upon on their deviations. If you want just to cut at the start or at the end it starts to be a little bit longer. At the end for a single point sensor it may be enough (just remeber to set the execution mode not to RELEARN, as long as it will reset you chages!)
Another (mathematical) way is to "trim" the curve - made by constructing "feature set" and indicating the name of the original scan, manually adding the point numbers you want to keep. Like SCN1.HITS[10..200]. This is quite good if you want automatically to trim starting or ending points ( normally you have to check the total number of points, so that the expression may be SCN1.HITS[10..VAR1], where VAR1 is a variablle assigned previously to SCN1.NUMHITS-10). If it is a 2D profile, I can also suggest to you to use a program, called CurveAnalyzer using it to show the profile and to select easily parts of the profile and others, just load the profile and do then whatever you want - http:\\ams3d.astrei.com. Has also better printing quality for the profiles.
Originally posted by Underspec View PostAnother way too is when constructing some features, you can choose segments of the scan.
by LAN_EMD19I have been using the manual scan on a fairly regular basis, but I come across a few instances where I need to delete some points from the scan I took....
12-06-2019, 01:16 PM -
by DeWain HodgeI have a "D" boss I'm scanning the outside of using a closed linear scan (SP25) and then picking the radii (create circle "segment of scan")...
12-22-2008, 09:23 AM -
by MrCommentHowdy folks.
Im waiting on PCDMIS tech support to call back with an answer to my question. I suspect I'll get quicker results here....-
03-05-2008, 12:40 PM -
by Jonde1Good Day Cmmers!
Does pc dmis give you the option to select individual hits from a scan to construct a feature for example a line or point??...-
06-29-2016, 08:04 AM -
by Benedictj1Is there a way after I analog scan all three sides at once to then profile the radial section by itself? (construct something from it?) I want to scan...
12-08-2016, 04:05 PM -
