Can't run DCC, get error message "waiting for in position". Anyone familiar with this? Seems to happen more often when machine has been shutdown for a while then restarted.
Error: Waiting for in position
what brand?
What make and model of machine is this?
This generally means that the commanded position has not been reached, so it keeps waiting, but the controller is not accurate enough to move it any more. Its a catch-22.
Nudge the machine with your finger to see if it helps it along. It might mean the the electronics require some tuning or adjustment. . .
You MAY have a wrap bad in the drive motor. I just started getting this error, it's a Z axis issue for me, all I have to do is RUB MY FINGER on the drive rod while hitting "continue" and it takes right off.sigpic
Originally posted by Matthew D. Hoedeman View PostYou MAY have a wrap bad in the drive motor. I just started getting this error, it's a Z axis issue for me, all I have to do is RUB MY FINGER on the drive rod while hitting "continue" and it takes right off.
Well - having disconnected the Z axis drive I found that the drive elements themselves were all very clean and free moving. However, I could hardly move the axis unit up and down by hand, so I adjusted some of the air bearings and it has been working fine since. I wasn't very scientific about my adjustments so I have to run some verification programs to see how it looks.
Brian
by dannyI got this warning in the morning.do you know guys what is the cause of it ?
Thanks , danny-
01-29-2009, 09:02 AM -
by Curty_82Has anyone ever gotten this error.. Its giving me this error when I home the machine.. Tesa V300DCC
Channel: PC-DMIS Vision
07-18-2013, 04:19 PM -
by newkidHello everyone! I am new at this forum and I recently start using PC DMIS. I have DEA GLOBAL. But I have a problem. After I create a program and start...
05-15-2012, 02:58 PM -
by dray7523Has anyone ever had their machine retract from a manual hit to the home position and then lock up the controller? If i take a hit in DCC, PC DMIS gives...
07-31-2014, 01:03 PM -
by bob0848Running 4.1 with TP20 module. Machine trips out both while moving and when not moving just sitting idle. The machine start on joy controller does not...
07-28-2014, 09:59 PM -
