Using 2022.1, In legacy you can define whether you want the true position of a cylinder at the Start, End, Average or Worst case. Can this be done using Geometric tolerance dialog box?
Cylinder true position
by HemingI know true position has been discussed before. But I still don't quite get it after reading these discussion. When I tried to find the true position...
05-18-2010, 09:21 AM -
by gszpotI have a customer that wants to know if the true position of a cylinder only measures the location of the cylinder or does it take the perpendicularity...
09-12-2016, 01:54 PM -
by ScottP815So I'm using PCDMIS 2020 R1, I have a 2 cylinders that have true position and perp. call outs. This seem redundant because the primary dat is the same...
04-16-2021, 05:27 PM -
by tnguyenHi. Could somebody explain to me how to apply Axial feature on cylinder true position. I have read on Reference manual, but I did not get it.
04-22-2006, 04:50 AM -
by WhydItDoThatThis is what I have. I'm not seeing this happening. I have two rotations, which is no problem. Just don't have any basics after that. And I've never TP'd...
11-15-2017, 04:34 PM -
