I noticed that in the edit window in PCDMIS 4.1 every number is in mm. I have yet to figure how to change it to inches so every location i create defaults to metric causing me to change to inches. I noticed an interesting issue though. In my location set to inches its randomly displaying my form in metric units it seems. This can definetly cause some problems as my reports are reviewed if i dont catch it.
metric mix up
There is no direct way to toggle your program from mm to inches. I believe there is a script on the hexagon website that will do it.
From now on do this... When you create a new program it pops a window and asks for a program name. Also in that window is the option to create the program in inches or mm. Yours must be checked to mm. Change it to inches once and I believe it will stay in inches. The techs like to change it to mm when they calibrate.
inches or mm is not a "bug"
it is your choice on what you need
if your print is in mm, it is easier to program with it in mm to start with...
same with inches
when doing your tolerances, you can toggle from one to the other.....sometimes prints have mixed dimensions...but rarelyWhich one gets ridden today? MPH vs MPG..tough choice, both are FUN
Starrett RGDC 4028-24 :alien:
Originally posted by jacyEd View PostCheck out the pic in my first post. Its mixing inches and mm in the same dimentional location in the report. Inches for diameter and mm for roundness.Last edited by JamesMannes; 06-13-2007, 09:22 AM.sigpic
Originally posted by JamesMannes View PostMaybe you haven't read through a lot of the posts on the forum. Most people are not using 4.1 they are either staying at 3.7mr3 using 4.2. Many problems with 4.0 and 4.1. I have been using 4.2 for many months now and see few errors/bugs.sigpic
PCDMIS 2012
Windows Office XP
by cmmguyyou have to change the DIMS you cant change the actual measurements without rewriting.
09-24-2008, 12:59 PM -
by JigneshI can select either mm. Or inch. Box when I make a new program in PCDMIS 2010. Did someone find new method so results would have appeared in report window...
02-14-2016, 01:45 AM -
techs,
i'm in the beginning of a program after loading my iges file and setting up my orientation and i just realized i have it in metric where...-
03-25-2009, 09:29 AM -
by SekharHi team,
I did the program in mm and running smoothly. I am using 2015.1 CAD ++ PC-DMIS .When I sent my program for validation purpose to...-
06-10-2019, 06:36 PM -
by Horizon101I know there is some real quick way to convert MM to inches s other than changing each individual number through out program. Is there a way to convert...
Channel: Tips & Tricks
12-07-2015, 12:16 PM -
