Angles from Cones
  • Angles from Cones
    Got a chamfer that I use auto cones for. Need an angle callout. Tried a few things but not working. Any ideas?
    Location A axis is included angle. What angle do you need?
      Thanks, never used cones much. Didn't realize it was that easy. LOL
        Doing a Location on the cone doesn't show me the angle of the chamfer.
          Be warned that the A gives the angle between the sides of a cone (included angle as Craig stated). Most of the drawings here call out the angle as the angle between the centerline of the cone and the side of the cone (1/2 the included angle).
          If you need to report that, use a variable and generic feature.
            Location, A does not report? What does it report as? I do measured cones but I'd think that it should be the same for an auto cone.
              Looks like it the angle of the two sides. Just used a variable to dimension 1/2 of it. Thanks.
                You don't need to create a generic feature.
                Use a variable (use a number AND letter in the name) to get your 1/2 angle, then use keyed in tolerance. Open the keyed in tolerance, enter your nominal and toleranced, then click OK. Change the measured number to what your assigned variable name is. Ctrl+E then unmark it. It will show up in your printout.
                You can use this method for anything that normal tolerancing will not work on.
                Duane
                Contura Calypso 5.4
                  Duane
                  I've never done that. Can you elaborate on how to create a "keyed in tolerance"?
                    Goodluck,
                    In 3.2063, it looks like a keyboard key in the toolbar. (Not scroll lock though). I use it when I have dimensions that need to be checked on a different piece of measuring equipment (optical comparator, profilometer, etc.), then I don't need to write all my non-CMM measurements down. They show up on the report. We often use the CMM and the report for 1st piece inspection.
                    John
                    P.S. I use the generic feature for cones, it is a personal preference. You may want to stay away from KEYED IN, as it is vaguley related to SCROLL LOCK.
                      Great now my eye just started twitching and all the voices started chanting "scroll lock". Thanks John.
                      sigpicYou're just jealous the voices talk to me.
                        I'm running V3.7MR3 too so it should be easy.
                        INSERT > DIMENSION > Keyin (bottom of list)
                        With the dialog box open, enter your nominal and tolerances then click on "Create".
                        Change the "MEAS" to your variable name and then CTRL+E, then unmark it. If you leave it marked, it will come up as a prompt when you run the program.
                        HTH
                        Duane
                        Contura Calypso 5.4
                          HTH
                          Duane
                          Thanks Duane, I'll give it a try.
                            Just make sure your variable name has at least one letter in it or the DEMON will make it a whole number.
                            Contura Calypso 5.4
                              You can cut out the variable step by using (FEATURENAME.A)/2 in the MEAS.
                              • GEllsworth
                                Dimensioning the angle of a cone
                                by GEllsworth
                                Using 4.2 CAD ++ and I know I figured this out in the past, but for some reason I can not get it to give me the correct angle of the cone. The drawing...
                                03-19-2009, 06:44 PM
                              • Londonjr
                                Inclusive angle
                                by Londonjr
                                How would I determine an inclusive angle? I am measuring a cone with a very minimal plane at the top of the part. (Maybe .002 land) 100 deg +/- 1 deg...
                                03-23-2016, 11:37 AM
                              • Scott D. Haselden
                                Reporting cone angles
                                by Scott D. Haselden
                                I searched the forum and couldn't find exactly what I was looking for. We are running 2019, and it is still new to us. I need to report a cone half angle....
                                08-15-2019, 12:34 PM
                              • mdobb829
                                Cone Angle
                                by mdobb829
                                When you report a cone angle is gives you the included angle. Can you make it report the angle of the taper, or as some call it, the per side angle?
                                07-01-2008, 11:17 PM
                              • Duke_26
                                Cone Angle /2 ???
                                by Duke_26
                                I am measuring a cone using the autocone feature on a shaft ( 3 levels, 10 hits each level ) and would like to know how I can report the angle of the...
                                02-01-2012, 08:10 PM
