missing lines in report
  • missing lines in report
    when generating report last line of page is getting hidden.
    any idea what's going wrong?
    Huh? I have no idea why that would happen. You may consider putting a formfeed command right before that dimension to force the whole dimension onto the next page. It wouldn’t fix the root cause, but it should help the symptom.
    • jigars
      jigars commented
      can you please share a code to see how it looks like or how to insert it.
    If there is more than one page displaying on the width of your monitor then page 2 is to the right not below.
      Delete the callout and re-create it.
        looks like it's happening at every page
          Pcdmis version?
          screen resolution? 1920 x 1080?
            Originally posted by SABarber View Post
            Pcdmis version?
            VERSION: 2022.1
            RESOLUTION: 2880 X 1800 (windows)
            Not sure how to check resolution for PC-DMIS
              Look at your OpenGL EDIT/Graphic Display Window
              • KIRBSTER269
                KIRBSTER269 commented
                Depends on your card, what do you have?
              • jigars
                jigars commented
                no clue, for some reason i'm using windows on Mac
              • KIRBSTER269
                see my pic, where it says Video accelerator, Mine says Radeon Pro WX 9100, What does yours say?
              for me it's same as windows resolution i.e. 2880 by 1800
                KIRBSTER269
                • KIRBSTER269
                • jigars
                  jigars commented
                  Is it visible now?
                https://www.amd.com/en/support
                Go download your driver here. Oh and change your Tessellation to .01, that way your cylinders don't look like a stop sign
                • jigars
                  jigars commented
                  thanks will share it with my IT person to install it
                • KIRBSTER269
                  good luck
                my suggestion would be to go to the pcdmis desired setting (Windows display settings) to see if that is causing the issue.
                Does the report print correctly or are the lines missing there as well?
