I have a program here with marked sets. When I choose to print to file, all the parameters are grayed out. I can't change what I want to name it as or the index number. Anyone know why?
Using v4.1.
I am trying to use marked sets for the first time. My program runs fine but I'm having a problem with printing. I have two print commands in my program...
I am having a probem with my inspection report not printing after the program is completed. I have the printing box checked in setup. This just started...
Is there a way to change Marked Set print options after the set has already been created? Or do you have to create an identical new one to set new print...
