so we have to check surface finish on all our product. we typically put this on the report using the manual key-in dimension. the issue im having is when i set the nominal to 0 and the plus tolerance to 250Ra the color scale still shows red even though its passing. what can i do so this does not turn red? I tried putting 125 nominal with a +/-125 but this messes with our SPC data. any help is much appreciated
