How can I add a CAD model to an existing program that was written without CAD? I realize that I'll have to transform/translate the model to get close to where the manual and DCC hits are shown in the program. So maybe a better question would be, how can I line up the model with the existing manual/DCC hits?
Adding CAD model to existing program
Normally if you import a CAD model and you translate/transform it to match your current alignment / zero point, by performing a cad=part you should be set to go. I suggest you create a copy of the original program before doing a cad=part because it cannot be undone later...
- Likes 1
Originally posted by constadin View PostNormally if you import a CAD model and you translate/transform it to match your current alignment / zero point, by performing a cad=part you should be set to go. I suggest you create a copy of the original program before doing a cad=part because it cannot be undone later...
IF you have access to CAD software. Add a coordinate ( 0.0.0) that matches the proper orientation of the CAD. Then it will import correctly. I would then redo the manual alignment and answer NO. These tasks are so much easier in CAD then inside DMIS. It may not be an option for you.
- Likes 1
Originally posted by Schlag View PostIF you have access to CAD software. Add a coordinate ( 0.0.0) that matches the proper orientation of the CAD. Then it will import correctly. I would then redo the manual alignment and answer NO. These tasks are so much easier in CAD then inside DMIS. It may not be an option for you.
by dcossI'm writing a program using just the CAD model and not the physical part. Is there any way to execute the program and to take manual hits using using...
10-11-2018, 02:20 PM -
by hitalovI was programin using the actual part, but i find out that there in a CadModel for it,
is there any way to add the MODEL and do PART=CAD aligment...-
04-09-2015, 01:56 PM -
by mtjohnI am combining 2 CMM programs with the same CAD model. There is a 45 degree difference in the CAD model orientation for the two programs. How can I transform...
03-14-2022, 02:52 PM -
by c_beardenhey folks.....Question....
We have several programs here that were written manually using the 1st pc part. Now I'm going in and inserting CAD models...-
03-02-2007, 03:42 PM -
by Rush2112our customer has changed some features on a model. What i want to do is import the new model and transform it to where the old model is so that i can...
12-18-2017, 03:29 PM -
