Use notepad or wordpad to open XML. I'm not sure excel can open it. Or are you confusing it with XLS? Are you needing an excel report of your measurements? Just wondering cuz as soon as I saw XML I was thinking excel as well.
select the excel tab, click o the check box in the top right corner. at that point you can select the prompt or auto and choose what folder you'd like it saved too.
I am having problems exporting my programs. When I export as a DXF or IGS file I get a program error or it just exits out of of the software. When I try...
I want to export as an AS3 file, but I don't have the option to do this. I'm using 3.5 no MR, should I be able to do this or is that option only available...
I'm running PcDmis 2016 sp9... I can get it to export an excel file in a csv format, but none of the values from the points I took show up in the file....
