Clearance Plane on Iterative Alignment
  • Clearance Plane on Iterative Alignment
    How do you put in a clearance plane within the program so that when a Iterative Alignment is done and the operator has taken a point way off, that it won't crash on the "Remeasure"?
    Tia
    Tia
    I don't know if this will help, but I generally use AUTOMOVE when I have to use an iterative alignment.
      Works after the last point was taken then it goes to do the sample hits for the circle on the re-measure then it crashes again.
        If you are talking about a manual iterative alignment then it prompts you to place the probe over the specified feature. If you are talking about a DCC iterative then you need to make sure the clearplane command is after the manual alignment, that way when PC DMIS goes back to remeasure features it picks up the command again. At least in 3.2 anyway.
        Kevin
          Good catch
            Originally posted by JamesMannes View Post
            Good catch
            Thanks James
            Kevin
              Like Matt said automove should sort it for you, I usually assign a label (label1)just before the first dcc iterative point then in the iterative alignment assign this the start label (label1). This should avoid any crashes when it remeasures
              To the Brave and the Faithful nothing is impossible
                Cool, thx all.I'll have a look at this, I'm running a program that was sent to me and the operator that was running some parts for me,wasn't taking the 3rd point used in the construction of the plane ,way off from where the program does.This was causing a crash (minor) and I'm looking at changing this program.
                Thx again for the tips.
