Just wanted to know if I am doing this right, created alignment using pins to locate center. Reset part on fixture. fixture moved.. used two other known holes on same axis created alignment. then used equate alignment to bring two together. Is this the right procedure. mid point checks ok. but first two pins check off set in y both in same direction .050. ? Nobody else here to bounce this one on thanks
equating alignment
Originally posted by kass_b View PostJust wanted to know if I am doing this right, created alignment using pins to locate center. Reset part on fixture. fixture moved.. used two other known holes on same axis created alignment. then used equate alignment to bring two together. Is this the right procedure. mid point checks ok. but first two pins check off set in y both in same direction .050. ? Nobody else here to bounce this one on thanks
IF you need to use EQUATE, the features used for BOTH alignments MUST be the same feature, exactly. Not 'close', not 'almost', but the exact same features from the previous alignment.sigpic
I am unable to get to pins that create a center line. and a midpoint at center of 500 lb bracket. I Measured holes in previouse alingment used those holes to create new alignment used same plane. translated. would I evean need to use equatesigpic
3.7 MR4
by CorbinHow do you do a equate alignment with a GD&T composite dimension. I got it to work somewhat... the holes appeared to be in the right position on...
09-12-2014, 12:29 PM -
by 12345V2011 MR1
Customer reported a part we delivered is OOT.
We have a copy of their program.
This part is a ring with multiple concentric...-
06-01-2012, 05:28 PM -
by TestedI thought that the equate alignment needed you to measure and create a originial alignment. Then measure some features that your were going to use in...
01-10-2007, 08:19 AM -
by sperryWhere would using this type of aignment be beneficial and how does it work?
10-02-2013, 08:53 AM -
by DeWain HodgeI have never used equate alignment in a program before, but I have a part coming up that I have to measure in two halves and I was wanting to use it instead...
08-07-2014, 06:19 PM -
