I have never used the auto round slot feature...never had the need. I programmed up a piece using it today...when I dimension the slot I seemingly can only get the overall length, do I need to use assignments to get the distance between the 2 radii of the slot?? Like below??
ASSIGN/V1 = SLT1.LENGTH-SLT1.DIAM
ASSIGN/V2 = SLT2.LENGTH-SLT2.DIAM
F1 =GENERIC/CIRCLE,DEPENDENT,RECT,OUT,$
NOM/XYZ,0,0,0,$
MEAS/XYZ,0,0,0,$
NOM/IJK,0,-1,0,$
MEAS/IJK,0,-1,0,$
DIAMETER/1.25,V1
F2 =GENERIC/CIRCLE,DEPENDENT,RECT,OUT,$
NOM/XYZ,0,0,0,$
MEAS/XYZ,0,0,0,$
NOM/IJK,0,-1,0,$
MEAS/IJK,0,-1,0,$
DIAMETER/2.75,V2
DIM LOC4= LOCATION OF CIRCLE F1 UNITS=IN ,$
AX MEAS NOMINAL +TOL -TOL MAX MIN DEV
D 1.2511 1.2500 0.0050 0.0050 0.0000 0.0000 0.0011 -----#---
END OF DIMENSION LOC4
DIM LOC5= LOCATION OF CIRCLE F2 UNITS=IN ,$
D 2.7506 2.7500 0.0050 0.0050 0.0000 0.0000 0.0006 -----#---
END OF DIMENSION LOC5
NOM/XYZ,0,0,0,$
MEAS/XYZ,0,0,0,$
NOM/IJK,0,-1,0,$
MEAS/IJK,0,-1,0,$
DIAMETER/1.25,V1
NOM/XYZ,0,0,0,$
MEAS/XYZ,0,0,0,$
NOM/IJK,0,-1,0,$
MEAS/IJK,0,-1,0,$
DIAMETER/2.75,V2
