Deep Bore Help
  • Deep Bore Help
    I currently have a weldement in house, one of the critical features is the concentricy of these two bores 3.997 Dia. I need some guidance as to how to check this...not that it is difficult, but I dont know what to order to get in there..(15.500 in). The machine has the envelope to check it...I understand that this might get expensive. We have both a tp20, and sp600..with a PH10MQ head.
    Tim
    You are going to have to cover most of that depth with extensions that fit between the PH10M head and the tp20 or sp600 head. I don't have any experience with a sp600. You can get the extensions in either carbon fiber or aluminum from Renishaw. Be very careful, especially if you try to index with the extension on there, give it lots and lots of room. HTH
      Get a long probe extension that works with the Autojoint, then use the "mushroom" shaped stylus that is a little larger than the tp20.
      Careful with concentricity checks like this if the bores are far apart, your results may not be satisfactory.
        I was kinda thinking about the auto joint extensions, but wasnt sure.
        Tim
          Without a drawing or sketch it is hard to be specific.
            Can you probe it from either side? Like a 90/90 then a 90/-90?
              I'm not sure if even an extended force TP20 can hold that kind of length. I would us the SP600 with a carbon fiber tip. Don't you have a renishaw catalog?
                New Purchase
                Well, I talked to Renishaw about this one...seemingly very helpful...We now have a 8mmx450mm Carbon Fiber extension and a 30mm start probe on order.
                If anyone is looking to outsource deep bore inspection, let me know...
                Tim
                  I would be reluctant to use a star probe... despite what Renishas told you.
                  Look at this link:
                  http://www.renishaw.com/resources/co.../5000-7814.jpg
                  Hemispherical
                    Hemi
                    We talked about the hemi..that is what i thought to use, what I didnt know is that it weighs 18grams..you would also need a m3-m2 adapter, even with an extended force module you would be fighting false triggers, bad measurements.
                      Yeah maybe... even on that short of a stylus?? I would be worried about the accuracy of the star probe enough that I would use an extended force module with the hemi before I used the star... The star is cheap enough to try it so let us know how it goes...
                        Hard to fathom that a hemi is heavier than a star. They are hollow ceramic balls. I haven't used one in a while but are they really heavier than a star?? Never would have guessed that.
                        Bill Jarrells
                          Weights
                          2mm - 30mm star probe weighs 1.8 grams
                          m3 - 30mm hemi - 18grams
                          .......From Renishaw catalog
                            WOW!! I just weighed my 2x30 star probe. 1.6 grams on our scale. Then I looked up the Ceramic Styli that I am thinking of A-5000-3614 (18mm Diameter and it fits M2 thread). Renishaw lists the weight as 3.3 grams. Still more than the star (surprised me) but not 18 grams. Of course, it isn't 30mm but 18 will get you around the extension and the TP20 as they run about 13mm and that is the size I was thinking of.
                            Regards,
                            Bill
                            Bill Jarrells
