Hey Matt, I was just curious if you are using 4.2 yet. I was looking for some expert guru type input on it. I cannot go back and forth between versions 4.1 and 4.2 without getting the "*#**%^" error message about the DimAnalysis ActiveX.ocx not registering. So I can't make a good comparison between the versions. Any noise - Let me hear ya's out there....
Matt H. - Are you using 4.2 yet
Originally posted by rerun_lives View PostHey Matt, I was just curious if you are using 4.2 yet. I was looking for some expert guru type input on it. I cannot go back and forth between versions 4.1 and 4.2 without getting the "*#**%^" error message about the DimAnalysis ActiveX.ocx not registering. So I can't make a good comparison between the versions. Any noise - Let me hear ya's out there....
As for Matt H. going to 4.2...
Do you know how long it was for him to go from 3.2063 to 3.7mr3? Wow brother let me tell you if you're waiting for Matt they'll be on 10.00 by the time you install 4.2(not that there is anything wrong with that).sigpic
LOL! Thanks James for the input. I did call tech support and I got the same instructions about manually registering the file. It does re-register the file but I should not have to do this every time I want to go back and forth, therefore their solution is no solution at all - ISN"T THAT ODD??? So I will call tech support back again and see what happens.sigpic
Cold Beer MMMmmmm........
Dell Precision T5400
Windows 7
B&S XCEL
WENZEL LH1512
PCDMIS 2011 MR1
Originally posted by craiger_ny View PostI bet Matt would know the fix if he was on 4.2..............
Good one Craiger!!!
I picked up a magic 8 ball the other day from ebay, I'll see if it can help rerun with his ocx problem. I think otherwise they do have a salve for that ocx thing.sigpic
Originally posted by rerun_lives View PostLOL! Thanks James for the input. I did call tech support and I got the same instructions about manually registering the file. It does re-register the file but I should not have to do this every time I want to go back and forth, therefore their solution is no solution at all - ISN"T THAT ODD??? So I will call tech support back again and see what happens.
BTW Craig, you could buy a rack direct from Renishaw, what you can't get without putting up the extortion $ is the interface in pc-dmis turned on.
Originally posted by craiger_ny View PostHaven't you heard? My SMA leaves me at 4.0. I'm living in 3.7MR3 land for as far as I can see.
I actually can't get a probe rack because of it.
Originally posted by cmmguy View PostI have been waiting for you to write a vb macro to load and unload a module in the rack.... Hmmm.....<internet bumper sticker goes here>
Go home made all the way. I don't think it would be too hard to work something out - hexagon did it afterall. All you need is a peice of steel with notches to catch the probe modules. Disable probe, move it into the notch, pull away, move to next desired notch, engage the module, drive away, enable probe.
Originally posted by craiger_ny View PostI'd do it if I knew I could. Thing is I don't want to lay out the nearly $6K to "experiment" with. I know nothing about the operation of a probe change rack, never used one.
VB Script for Probe rack
hmmm?
I don't know but if I get some "free time" i'll giv it a go.
How about sombody posting out a probrack change in DMIS for us to start?
Gsigpic
Originally posted by Cumofo View PostI think you could write the operation in DMIS as a separate program with its own alignments and call it in through an external program?
hmmm?
Gsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Originally posted by Wes Cisco View PostI would if I knew how. All I do is put a loadprobe command in my code and pc-dmis goes to the rack and retrieves the probe. If you can tell me how to print that in DMIS I will.
Same here I have a tp200 rack.....waiting on the tp200 though. Mine brokesigpic.....Its called golf because all the other 4 letter words were taken
by bob mappesI just had a call from Hexagon saying that 4.2 is officialy released and a CD is being put in the mail .
thought I would share...-
06-07-2007, 03:52 PM -
by John RigginsIf you are using Version 4.0, 4.1, or 4.2 and you had a choice to revert back to a previous version would you?
Why?Yes, if a New York minute.44.44%16No, I am happy with the newer version55.56%20-
08-10-2007, 06:08 PM -
Does anyone know when B&S will officially release 4.2???
06-18-2007, 06:45 PM -
I just loaded 4.2 two days ago. I going to re-load 3.7mr2. Does anyone else think this is cumbersome and too complicated. Maybe I haven't given it...
06-14-2007, 11:15 AM -
by mhesseI just saw that Vers. 4.2 is "officially" relased from Wilcox as of 5-9-07.
05-10-2007, 04:28 PM -
