When setting up scans and running it for the first time it scans fine. But when I go to DCC mode and run the program, the thing does point to point scans. What's going on?
I'm using v4.1 with a SP600M.
Instead of the choice "normal" you need the "relearn" method of scanning. I use "relearn" and "find nominals". SP600 also, Chameleon 9-15-9 Sharpe 32z w/Leitz protocol.
OK, I'm new to scanning and I have a problem. I just finished a program with multiple scans, when I tried to then run the program in DCC mode all of my...
