How do you....
  • How do you....
    I have upgraded 4.0 to 4.1 recently. Do anybody knows how do I change parameters where the probehead travels after it goes home? If I started it up with 4.0 it goes home then travels back couple of inches in all directions from the home. Well in 4.1 it does the same thing but its crashing into my ATC.
    Pc-Dmis 4.2, Zeiss Eclipse
    All four of our B&S machines home to the front upper left. Where is yours homing?
    sigpic GDTPS - 0584
      Same here, but this one is a Zeiss machine before it was outfitted with PC DMIS it just vent home and stayed there, but after it was outfitted with the new software it goes home then backs away from it for some reason, but on 4.0 it did not crashed into my probechanger.
        You are not making any sense. How does the probe head go home then crash into your probe changer? You have your changer under the home position? Usually racks are in the back. Please explain in more detail.
          The home position of the machine is at upper left corner of the machine all the way to the back at least it was the home position of the machine when I had the original zeiss software installed. It used to go to this position and stayed there. After they outfitted this machine with PC- DMIS the zero position changed. Its still travels all the way back to end of the machine but when it reach the limit it will moves back so now its traveling back towards the front of the machine in all three axises. I had no problem with it with 4.0 because probehead cleared the proberack, but in 4.1 it doesn't clear it. The probrack is at the back of the machine. I drew a sketch, hope it does help.
            Sorry, I have no idea. 1-800-343-7933
            sigpic GDTPS - 0584
              Change the position of the rack and recalibrate
