I have a Center Post that is formed from a welded tube. The axes is the ID. Two given diameters from two different cones. The setup is not the problem. What I would like help on is this. The end of the tube is where X axes should be set, but at the lowest point. The way the tube is formed. The end of the tube is not real square to the axes. I would like to take a number of points on the end of the tube. Is there a way to for the software or script that someone knows about to find the lowest point. I know you can construct a high point plane. Thanks for the Help.
Sheffield RS50
3.7MR3
Sheffield RS50
3.7MR3
