My problem is the construct circle box is too large to show the create button
after highlighting the pts used to construct the circle. Any ideas? using 4.2
Change screen settings to value higher than 1024 x 768 and the entire box will show up. Had the same problem and saw no other way around it. 'MAYBE' when you go to higher setting you can shrink it then go back and the new size will be saved? Don't know - haven't tried.
Bill Jarrells
Nope, none of the pop-up (at least, none that I know of) can be re-sized in Pcdmis. They are a certain number of pixels wide and a certain number high. So, if it is bigger than your resolution, you will not be able to see all the box. The higher you crank the monitor resolution, the 'smaller' the boxes will get. I have mine at 1600x1200.
Well, it's huge, that's for sure.Tryed to move it, flip, dock, get off the screen(23 inches)...no will do.
I know, you don't want read this, but...
Inside my place of work, I'd use it to get new eqiupment (BIG screen).
Sorry for not being usefull.
Increase your screen resolution to as good as your eyes can handle and increase your refresh rate to as high as your monitor will go.
Well, as high as it will go for the resolution you choose, the higher the res, the lower the refresh. Best bet for you eyes is to use the highest resolution that will support a MINIMUM of a 70 refresh rate.
OR, get an LCD monitor, no flicker issue with refresh rate.
Say the construct line box is so tall that the buttons at the bottom of it get hidden by the bottom tool bar and its hard to cliclk on the create or close....
Question.........being that I'm running DMIS 42.MR1, what I would like to know is if there is a way to eliminate the feature theoretical box's, the reason...
good afternoon folks...once again i have a new question. im running 4.2 at the moment. i was wondering: when i pull up some of my construction features...
