What is the correct procedure for establishing mechanical offets? I have talked to 3 different tech support reps and got three different procedures and none of them work. All I want to do ise set the location of the Calibration Sphere. MEA Position is close but not correct. I want to set it correct. Is that possible?
Mechanical Offsets
Originally posted by Wingman View PostWhat is the correct procedure for establishing mechanical offsets? I have talked to 3 different tech support reps and got three different procedures and none of them work. All I want to do ise set the location of the Calibration Sphere. MEA Position is close but not correct. I want to set it correct. Is that possible?sigpic
It's a sheffield interface specific function James.
Wingman,
Put the SMI supplied MEA sphere in the correct hole on your machine. Build a brand new probe file (or reset a componant of a current one to clear the .prb file out) and then run the calibration routine using the MEA_MECHANICAL_OFFSET_SPHERE in the tool selection combo box (you also need to say YES to the sphere moved question if you want to update the offsets). If you dont have this sphere defined you can build it, but its important the name be correct (PC-DMIS should define this for you on install if your porlock is set up right)
When the calibration is finished you will get a message box letting you know what the calculated mech offsets are click ok and it saves them to the controller.
If you are tossed an exceed tolerance error, it's most likly a probe file built incorrectly and you now have bad offsets. Make sure you dont save bad offsets to your controller.
I realize you did this, but Tech Support is the way to go here. They have a nice document that goes through procedures for setting the offset, calibrating at the MEA, and also calibrating at non-MEA. It's worth having.Last edited by mkopesky; 06-04-2007, 08:11 PM.
Originally posted by mkopesky View PostIt's a sheffield interface specific function James.
Wingman,
I realize you did this, but Tech Support is the way to go here. They have a nice document that goes through procedures for setting the offset, calibrating at the MEA, and also calibrating at non-MEA. It's worth having.sigpic
I would be very interested in the document WITH the missing step. Thanks VERY much for the help here. This is driving me mad!! LOLBill Jarrells
I have a document that appears to be missing this step. Are you saying that I should go into PC DMIS Settings Editor and change the Tool MEA X Y and Z positions to Zero and then run the Mechanical Offset?Bill Jarrells
Well, I created a sphere call MEA_MECHANICAL_OFFSET_SPHERE and calibrated with 'change' location. MEA Sphere is still off 4mm in X, 3mm in Y, and 1.5mm in Z so the issue I wanted to correct was not corrected. Every tip calibrated still thinks the sphere is located 'close' but not 'exactly where' it is. They offset OK and all. I just want to be able to add angles without crashing into the ball. Hmm.Bill Jarrells
I just blew away all the Calibration Spheres. Started from scratch and named one MEA_MECHANICAL_OFFSETS_SPHERE and named one MEA_CALIBRATION_SPHERE. I changed location for both of them and now they are defined where they are supposed to be. Program seems to be doing what I want. I will have to wait until 4x50 is completely calibrated and I will check the settings editor to see if the correct values are there for keeps.Bill Jarrells
Originally posted by Wingman View PostI have a document that appears to be missing this step. Are you saying that I should go into PC DMIS Settings Editor and change the Tool MEA X Y and Z positions to Zero and then run the Mechanical Offset?sigpic
by BeckyKI am writing a calibration program on a Sheffield RS-70. Because of the length of the tip, we cannot calibrate all tips in MEA position, so I moved MEA...
05-10-2011, 11:18 AM -
by ElroyCarbonHello all . . . so off the bat I understand the version we're running is quite old. PCDMIS 2001 to be precise. I'm having an issue calibration any probe...
10-26-2015, 10:59 PM -
Hello
2010 MR3, this is a Sheffield machine.
I came in this morning and the cal sphere was not in the MEA position. We measure A0B0 in the...-
02-28-2011, 12:28 PM -
by TOMW.Our Calibration Sphere Location seems to have been relocated to different 'default' position.
(I use the word 'default' for want of a better term.)...-
07-14-2015, 07:28 AM -
Hello all,
I have what will probably be an easy issue to fix but is taking me forever to figure out. I recently reset the software to restore...-
11-21-2017, 04:53 PM -
