tcp/ip comunication failed switch to rs-232
  • tcp/ip comunication failed switch to rs-232
    does any one know what this error means
    I have to answer yes or no
    thanks
    PC-DMIS CAD++ 4.3 MR1
    Shut down your controller, computer, and CMM. Restart and you should be good to go. Ethernet connection was lost. This will re-establish the connection.
      More information
      James is correct, I wanted to add some information as this happens to me frequently. With the Leitz controllers you typically have a choice of serial communications (RS-232) or ethernet (TCP/IP). If you were just measuring features with a few hits each, you would likely never know the difference. If you start scanning with analog probes (SP600, SP25, etc.) you would see a difference in throughput. This is because the scans sends massive amounts of data from the controller back to the PC and TCP/IP can handle this much more easily.
      In your configuration (Edit - Preferences - Machine Interface) there is a tab with a checkbox to indicate "Use TCP/IP" or something similar. If this is not checked, then it is using RS-232. For many programs it does not matter how this is set. When I typically get this problem is when I am using PC-DMIS and I get an error that appears to throw me completely out of the application. Re-starting PC-DMIS then gives me the error message. This is because the application did not completely shut down. A quick check of the task manager would reveal that the PCDLRN task is still running. If this is the problem, then re-boot is not necessary, you need only to kill the task and then re-start PC-DMIS. This is not the only time this problem occurs, but it is the most common for me.
      • jon_dav_uk
        Help !!
        by jon_dav_uk
        Does anyone know how to get the static IP Address of a controller (B3CLC).
        We have a new PC but cannot get it to talk to the controller...
        10-30-2008, 03:06 PM
      • operator1
        TCP IP Send Error?
        by operator1
        Can anybody tell me what the heck this means? I had to shut off my CMM because it kept poppin up.
        12-12-2007, 02:24 PM
      • volsmo
        Default IP Address
        by volsmo
        The TCP/IP settings on our CMM computer have been lost. Can anyone tell me the proper IP settings for a Brown Sharpe Global Performance CMM.
        We...
        03-09-2010, 09:09 AM
      • CGoode
        TCP/IP Error
        by CGoode
        Any body know how to correct this error? I am not being shut down over it I just switch to RS-232. I believe it has to do with having the machine set...
        06-27-2007, 05:04 PM
      • GEllsworth
        Tcp/ip error
        by GEllsworth
        Updated the computer and now a TCP/IP error is happening. I tried searching some of the threads with no luck. I recall it has to do with a network setting...
        12-15-2012, 11:40 AM
