Some idiot (ie an engineer) has taken off with my description sheet that shows what all the little symbols on the prints mean. Any of you that work with these Ford prints know what I mean, (h) and (H) and (s) and (S) are but a few of them. Do any of you have that sheet and could you post a copy of it for me? Thanks.
FORD (fo-mo-co) print symbols
Originally posted by rangerboat72 View PostDon & I work with Ford drawings all the time but for the life of me I cannot locate a sheet that explains all of the symbology . . .(really i do!)
Kev
RFS Means Really Fussy Stuff
I should have a copy of the sheet sometime this evening and I will post it here. In the mean time, here are a few of the meanings:
S, H, E with a circle around them - Principal Main Locators
s,h,e with a circle - Principal Secondary Locators
HK, SK, EK with a circle - Permanent Transfer Main Locators
hk, ck with a circle - Perm Trans Secondary Locators
Symbols with a diamond around them are Temp Transfer Locators
There is sort of an equation symbol that is used to list Functional Subscripts and I have those if you need them (O,S,K,C,F)
H, S or E with a square is a Main Assembly Locator
h, @ are secondary assy locators
CH with a circle - Coordination Locator
CK with a circle - Correctable Locator
CO with a circle - Auxillary Rest Locator
SL with a circle - Scribed Coordination Line
AC " - Access or Clearance Hole
DL" - Detached Locator
BL " - Blank Locator
J " - J-clamp
Hope this helps. I will post the sheets when I get them.
Originally posted by gcunniff View PostI should have a copy of the sheet sometime this evening and I will post it here. In the mean time, here are a few of the meanings:
J " - J-clamp
Hope this helps. I will post the sheets when I get them.sigpic
Originally posted by Matthew D. Hoedeman View PostSome idiot (ie an engineer) has taken off with my description sheet that shows what all the little symbols on the prints mean. Any of you that work with these Ford prints know what I mean, (h) and (H) and (s) and (S) are but a few of them. Do any of you have that sheet and could you post a copy of it for me? Thanks.
H or h Hole and/or for pin/stud location.
S or s Surface.
E or e Edge, end, corner or notch.
X fore/aft
Y in/out
Z high/low
Hope it helps Matt.sigpicIt's corona time!
fyi-->3
HTHGlobal S Blue 12.15.10 HH-AS-T2.5 / HP-S-X1h |PC-DMIS CAD++|Quindos7 CAD; Leitz Reference Xi 15.9.7
by d.evansI understand that PCDMIS CAD++ has the ability to find sheet metal features when they aren't where they are supposed to be because of the inherent inconsistency...
06-08-2006, 01:22 PM -
by CookieDoes anyone have a list of the abbreviations for the callouts?
10-14-2009, 11:17 AM -
by matl59Im working with a gantry style machine and a large cylindrical part with a sheet metal section. In the sheet metal all the way around the circumference...
Channel: PC-DMIS NC
11-11-2009, 12:27 PM -
by sbd_80Hallo.
Does anyone know the function and influence of sheet metal options? You find them as an addtional item in nearly all parametic features...-
02-15-2008, 09:05 AM -
by MisfitIs there a sheet metal application or program add on for PC-DMIS? I thought I heard mention of it in one of my training courses. We're measuring 14-20ga...
12-01-2010, 02:13 PM -
