Just starting to use 4.2. The question I have is why do I have to select surfaces on the model in order to generate a linear open or closed scan? Was using 3.7mr3 and only had to select surfaces for perimeter scans. Am I missing something or is it necessary to select surfaces for all scanning in 4.2. Thanks in advance.
4.2 scanning
Originally posted by scanner View PostJust starting to use 4.2. The question I have is why do I have to select surfaces on the model in order to generate a linear open or closed scan? Was using 3.7mr3 and only had to select surfaces for perimeter scans. Am I missing something or is it necessary to select surfaces for all scanning in 4.2. Thanks in advance.
On the topic of scanning. I had a problem today scanning in 4.2. I thought it might be 4.2, but after careful inspection of the problem it turned out that I had a small piece of dirt between the magnetic cap and the body of the probe.sigpic
by scannerIn 3.7 and below I only had to select surfaces in order to generate a perimeter scan. I am playing around w/ 4.2 today and in order to get my linear...
05-28-2008, 03:32 PM -
by AJHVW93Your opinions would be greatly appreciated!! I know alot of users are high on 3.7mr3. How about for scanning???
06-01-2007, 11:55 AM -
by BSchwarkSP-600 Global 3.7MR2.
I am trying to scan using customer program. Everthing runs good until I reach the scanning portion of the program. The portion...-
06-19-2006, 04:36 PM -
by jimbobI just completed loading 4.2 MR1, and now I'm having patch scan issues.
Anyone else hve this issue, or is Jimbob going crazy, dun fell off his...-
04-22-2008, 10:50 AM -
