Legacy Dimensioning In 2020 R2
  • Legacy Dimensioning In 2020 R2
    Does anyone have a solution on how to remove the size dimension from a true position callout, when using Legacy Dimensioning in 2020 R2?
    I used to be able to do it in R1 by just not giving the DF aspect tolerance, but now it reverts to the baseline ± .0004" on size and gives me red on a report.
    I use pins to verify size as most of the stuff we do has paint within and skews the results with size average math nonsense.
    I just want to report position without size. Someone has to know the way
    Right-click the report label in the report window, select "Edit Object...". On the left hand side of the window that appears, uncheck the DF row. Press OK.
    To make it permanent, you can modify the report label.
      Ding ding ding, winner!
      Thanks Jacob.
