prevent pcdmis to enter hole from the side with sample hits turned on
  • prevent pcdmis to enter hole from the side with sample hits turned on
    Hi, is there a way to force the machine to always enter a hole from the center like it does when 'sample hits' is turned off?
    With 'sample hits' on, it wants to enter from the side and often/sometimes crash into the part because reasons.
    I hate that stupid thing.
    He had a baseball bat and I was tied to a chair. Pissing him off was the smart thing to do. - Max Payne 2001
    A few things to try...
    1) Try giving yourself more PREHIT and RETRACT.
    2) Make sure you're Z height for the feature and depth are set up correctly and that you're not robbing yourself of movespace accidentally due to messed up settings.
    If still messed up...
    3) Make the feature just to get in your edit window. Switch to COMMAND mode if you don't already use it. Make "SHOW CONTACT PARAMETERS" equal "YES" and then make "SHOW HITS" equal "YES" to expand the code open and you'll see a list of the actual points that make up the autofeature. Outside of the autofeature, create a move/point with coordinates for above the hole. Then, cut & paste that move/point from outside of the autofeature to INSIDE of the autofeature in front of the first hit. PCD is annoying, you'll probably have to close the "show hits option" on the autofeature and then re-open it to see the move/point now successfully displayed in your code as it is shown in mine.
    CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<3.1496,2.3622,0>,<0,0,1>,2.3622
    ACTL/<3.1496,2.3622,0>,<0,0,1>,2.3622
    TARG/<3.1496,2.3622,0>,<0,0,1>
    START ANG=20,END ANG=380
    ANGLE VEC=<1,0,0>
    DIRECTION=CCW
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    NUMHITS=7,DEPTH=0.1968,PITCH=0
    SAMPLE METHOD=SAMPLE_HITS
    SAMPLE HITS=1,SPACER=0.15
    AVOIDANCE MOVE=NO,DISTANCE=0.3937
    SHOW HITS=YES
    MOVE/POINT,NORMAL<3.14,2.36,1>
    HIT/BASIC,<4.2595,2.7662,-0.1968>,<-0.9396926,-0.3420201,0>,<4.2595,2.7662,-0.1968>
    HIT/BASIC,<3.5258,3.4818,-0.1968>,<-0.3184867,-0.9479273,0>,<3.5258,3.4818,-0.1968>
    HIT/BASIC,<2.5088,3.3544,-0.1968>,<0.5425463,-0.8400259,0>,<2.5088,3.3544,-0.1968>
    HIT/BASIC,<1.9744,2.4798,-0.1968>,<0.9950308,-0.0995678,0>,<1.9744,2.4798,-0.1968>
    HIT/BASIC,<2.3249,1.5167,-0.1968>,<0.6982368,0.7158668,0>,<2.3249,1.5167,-0.1968>
    HIT/BASIC,<3.2965,1.1903,-0.1968>,<-0.1243437,0.9922392,0>,<3.2965,1.1903,-0.1968>
    HIT/BASIC,<4.1574,1.7463,-0.1968>,<-0.8532909,0.5214352,0>,<4.1574,1.7463,-0.1968>
    ENDMEAS/
    You could also try a BEFORE avoidance move, but I don't think that will help you. That will get you to feature center BEFORE the CMM takes the sample hits but it won't stop you from clipping the surface of the material.
    Lastly, try the FINDHOLE option. It works in conjunction with your PREHIT & RETRACT & CHECK distances.
      Have you tried find hole center, (last tab)
        I always use avoidance moves. Seems to work with me. When you use avoidance moves before, make sure you set the distance.
        Darroll
        2018R2
          Make the Feature hole smaller than it actually is and the check distance bigger. For Example 1 inch hole. create it so that it's a .990 or whatever. Make sure your Check Distance is at least .01 to make up the difference. I'll do this with sheet metal, because those holes never seem to be in the right spot. All ideas above are better, just throwing this one in the mix also.
          • tking
            tking commented
            Another option is to make prehit / retract values 1/2 the hole diameter, it'll drive from the nominal center.
          • KIRBSTER269
            KIRBSTER269 commented
            tking I would have given you a like there but you posted under comment
          • tking
            tking commented
            Thanks, Kirbster, but hey I like you anyway!
          Thanks for the suggestions, i was hoping for a toggle switch/checkbox
          i'll play around with the suggestions and hope i find something that work with all holes.
          Just really annoying when it happens, when the technology for center penetration exist.
