Open the report template you use in the template editor.
Select File | Save As and create a new report template based off the one you opened.
Select the TextReportObject and right-click on it to access its Properties.
Select Colors from the Properties dialog.
The Color Editor appears. This is the same editor as used for the Edit window, but in this case it modifies the TextOnlyObject used in your report template.
Make your changes, save the template, load it into the Report window.
Got a problem I can't seem to fix - Runout shows on the report as a pale green, when printed you can't see it. How do I make the type color default to...
