2016 Circle filtering
  • 2016 Circle filtering
    We measure many parts with 3 internal segments that define a diameters. The filtering guide states that using a cylindrical filter is appropriate for this application.
    My question is, if I constructed a circle using a gaussian filter from the 3 scanned segments would it be the same as individually filtering using the cylindrical filter?
    Edit:
    So I tested it on one circle.
    Max inscribed circle Cylindrical filter Diameter = 44.9942 Roundness = 0.0031
    Max inscribed circle Gaussian filter within the constructed feature Diameter = 44.9931 Roundness = 0.0038
  • IZAKK
    Form: Roundness
    by IZAKK
    Does anyone know how roundness is calculated when you select the option from the FEATURE LOCATION window? I have a cylinder that i want to see the roundness...
    04-23-2009, 12:23 PM
  • PekkeriMan4000
    Max Inscribed diameter
    by PekkeriMan4000
    Hello,
    I`m measuring a setting ring diameter (nominal diam 69.994 mm) to check the touch-trigger probel lobbing error. I created an auto-circle...
    03-04-2019, 08:16 AM
  • gcunniff
    Circle Diameters
    by gcunniff
    I'm having an issue with hole diameter in a plastic injection part. The hole is out of round approx. 0.020" I've run a scan of the diameter and...
    04-18-2007, 10:55 AM
  • Rob Knoerlein
    A Boss' Question ....
    by Rob Knoerlein
    Okay Friends....The part is a simple 6x6 inch square of material 1/2 inch thick. There is a 4 inch diameter bore centered in the middle of the part. I...
    05-01-2008, 11:10 AM
  • TommyArrow
    circle - eggshaped
    by TommyArrow
    When a circle feature is created and then reported , specifically the diameter, and say the circle/bore is "egg" shaped which everything will...
    06-21-2013, 10:14 AM
