Need opinions - Circular runout of a diameter to two datums.
  • Need opinions - Circular runout of a diameter to two datums.
    I have the following callout on a print. With -A- being a plane and -B- being a cylinder. Currently the way this is dimensioned does not seem right to me.
    Alignment is created using -A- and -B-, and then the Ø49.75 (as a circle) is dimensioned Circular Runout to the Origin (created from A and B). I say this is a bad callout and it should be two seperate callouts.
    What say you??
    Thanks in advance.
    Call out is legal as per my British Standards book.
      I agree. I think it should be two separate callouts.
      • LaserJay
        LaserJay commented
        I may have spoken too soon. I just looked at the ASME (1994 Page 49) and they have an example of a runout callout with two datums in the FCF.
      • LaserJay
        LaserJay commented
        They also have it called the same way in the ASME. Primary is a plane (perpendicular to the hole) and secondary is a diameter (in line with the hole)
      But is dimensioning that diameter to "The Origin" correct?
        Level A Rotate to B or stop on highest point or points , I'm guessing that A is a Cylinder and B is a Plane? It would technically be like putting the part on a 3 chuck jaw to level the cylinder and pushing it up against the jaw to touch the 2 highest points or even a point and running an indicator on D
          Hopefully the title block or notes specifies ASME Y14.5-2018, which has in it's forward: ". . . use of concentricity and use of symmetry symbols, are no long supported. Both have been eliminated because other characteristics provide more direct control of features and establish requirements that have a well-defined meaning."
          • KIRBSTER269
            KIRBSTER269 commented
            and I was so glad when you announced they got rid of these 2 crappy callouts, what was it? 2 years ago when you posted that?
          Callout is legit.
          While recalling startup alignment, create a generic plane with an X+ vector.
          All in one alignment.... Level to -A-, rotate w/ generic plane to the X+ about the Z, make the cyl your X&Y origin and make the plane your Z.
          Then measure the feature as a cylinder. Use a fair amount of hits & levels, you want to cover as much surface as you can. Report the runout of the cyl back to your origin.
