Export the result with excel problem
  • Export the result with excel problem
    Hello, my part three dimensions with two cavities part. When I generate the excel report, it will create dimension 1 for cavity 1-2, then dimension 2 for cavity 1-2, dimension 3 for cavity 1-2. When I delete the steps to measure dimension 3, the program ran fine but it creates the report different order. It report dimension 1 cavity 1, dimension 2 cavity 1, dimension 2 cavity 1, ddimension 2 cavity 2. How can I fix so that it will generate the report for first dimension for all cavities and then dimension 2 for all cavities without write the new program? I thank you in advance.
