Measured results and reported results different
  • Measured results and reported results different
    I'm measuring a small, interrupted surface sphere with good results. The THEO and ACTL vary by .0024 max. When I ask for Position on that same feature, without any steps between measuring and dimensioning the position of sphere, I get a max variation of 3.1043 and a reported position of 7.5252. Calculate same sphere using the ACTL results, position is .0055. See SPH1 in attached program (partial program, too long to post complete)
    CIR6 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<-4.66,-0.14,0>,<0,-1,0>,0.8125
    ACTL/<-4.6592,-0.14,0.0036>,<0,-1,0>,0.8124
    TARG/<-4.66,-0.14,0>,<0,-1,0>
    START ANG=0,END ANG=0
    ANGLE VEC=<0,-1,0>
    DIRECTION=CCW
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    NUMHITS=7,DEPTH=0,PITCH=0
    SAMPLE METHOD=SAMPLE_HITS
    SAMPLE HITS=0,SPACER=0
    AVOIDANCE MOVE=NO,DISTANCE=0.3937
    SHOW HITS=YES
    HIT/BASIC,<-4.2538,-0.14,0>,<-1,0,0>,<-4.2531,-0.1401,0.0002>
    HIT/BASIC,<-4.4067,-0.14,0.3176>,<-0.6234898,0,-0.7818315>,<-4.4047,-0.1401,0.3202>
    HIT/BASIC,<-4.7504,-0.14,0.3961>,<0.2225209,0,-0.9749279>,<-4.7509,-0.1401,0.3993>
    HIT/BASIC,<-5.026,-0.14,0.1763>,<0.9009689,0,-0.4338837>,<-5.0267,-0.1401,0.1766>
    HIT/BASIC,<-5.026,-0.14,-0.1763>,<0.9009689,0,0.4338837>,<-5.0241,-0.1401,-0.1752>
    HIT/BASIC,<-4.7504,-0.14,-0.3961>,<0.2225209,0,0.9749279>,<-4.7494,-0.1401,-0.3924>
    HIT/BASIC,<-4.4067,-0.14,-0.3176>,<-0.6234898,0,0.7818315>,<-4.4082,-0.1401,-0.3159>
    ENDMEAS/
    CIR7 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<-4.66,0.14,0>,<0,-1,0>,0.8125
    ACTL/<-4.659,0.14,0.0037>,<0,-1,0>,0.8124
    TARG/<-4.66,0.14,0>,<0,-1,0>
    ANGLE VEC=<0,-1,0>
    DIRECTION=CCW
    SHOW HITS=YES
    HIT/BASIC,<-4.2538,0.14,0>,<-1,0,0>,<-4.2528,0.1399,-0.0002>
    HIT/BASIC,<-4.4067,0.14,0.3176>,<-0.6234898,0,-0.7818315>,<-4.4046,0.1399,0.3204>
    HIT/BASIC,<-4.7504,0.14,0.3961>,<0.2225209,0,-0.9749279>,<-4.7509,0.1399,0.3993>
    HIT/BASIC,<-5.026,0.14,0.1763>,<0.9009689,0,-0.4338837>,<-5.0265,0.1399,0.1765>
    HIT/BASIC,<-5.026,0.14,-0.1763>,<0.9009689,0,0.4338837>,<-5.0239,0.1399,-0.1751>
    HIT/BASIC,<-4.7504,0.14,-0.3961>,<0.2225209,0,0.9749279>,<-4.7494,0.1399,-0.3923>
    HIT/BASIC,<-4.4067,0.14,-0.3176>,<-0.6234898,0,0.7818315>,<-4.4082,0.1399,-0.316>
    ENDMEAS/
    COMMENT/REPT,
    # 20, 21, 52 & COMMON CENTERLINE (2 LEVELS)
    DIM LOC8= POSITION OF CIRCLE CIR6 UNITS=IN ,$
    GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH FIT TO DATUMS=OFF DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER
    AX NOMINAL +TOL -TOL BONUS MEAS DEV OUTTOL
    X -4.6600 -4.6592 0.0008
    Z 0.0000 0.0036 0.0036
    DF 0.8125 0.0003 0.0002 0.0004 0.8124 -0.0001 0.0000 --#------
    D1 0.9260 0.0010 0.0010 0.0011 0.9261 CIRCLE CIR_B_ AT MMC
    TP LMC 0.0100 0.0014 0.0073 0.0073 0.0000 -----#---
    END OF DIMENSION LOC8
    DIM LOC9= POSITION OF CIRCLE CIR7 UNITS=IN ,$
    X -4.6600 -4.6590 0.0010
    Z 0.0000 0.0037 0.0037
    DF 0.8125 0.0003 0.0002 0.0004 0.8124 -0.0001 0.0000 -#-------
    TP LMC 0.0100 0.0015 0.0076 0.0076 0.0000 -----#---
    END OF DIMENSION LOC9
    CYL1 =FEAT/CYLINDER,CARTESIAN,IN,LEAST_SQR,NO
    THEO/<-4.66,0,0>,<0,1,0>,0.8125,0.28
    ACTL/<-4.6591,-0.0001,0.0036>,<0.0007772,0.9999997,0.0003091>,0.8 124,0.2807
    CONSTR/CYLINDER,BF,CIR6,CIR7,,
    COMMENT/REPT,
    # 22 (ON CYLINDER CREATED FROM ABOVE CIRCLES)
    DIM PERP1= PERPENDICULARITY OF CYLINDER CYL1,MMC TO PLANE PLN_C_,RFS EXTENDLENGTH=0.0000 UNITS=IN ,$
    DF 0.8125 0.0003 0.0002 0.0001 0.8124 -0.0001 0.0000 --#------
    M 0.0000 0.0020 0.0000 0.0001 0.0003 0.0003 0.0000 -#-------
    MOVE/POINT,NORMAL,<-4.6395,0.139,-0.247>
    MOVE/POINT,NORMAL,<-4.635,-0.6896,-0.2446>
    MOVE/POINT,NORMAL,<-4.2266,-0.4931,-0.0218>
    PNT1 =FEAT/POINT,CARTESIAN
    THEO/<-3.94,-0.4918,-0.0234>,<-1,0,0>
    ACTL/<-3.9433,-0.4919,-0.0234>,<-1,0,0>
    MEAS/POINT,1,WORKPLANE
    HIT/BASIC,NORMAL,<-3.944,-0.4918,-0.0234>,<-1,0,0>,<-3.9433,-0.4919,-0.0234>,USE THEO=YES
    ENDMEAS/
    COMMENT/REPT,
    # 38 (1 OF 2 PLACES)
    DIM LOC10= LOCATION OF POINT PNT1 UNITS=IN ,$
    X -3.9400 0.0000 0.0050 -3.9433 -0.0033 0.0000 ---#-----
    END OF DIMENSION LOC10
    MOVE/POINT,NORMAL,<-4.4106,-0.4941,-0.0206>
    MOVE/POINT,NORMAL,<-4.9109,-0.4363,0.7121>
    MOVE/POINT,NORMAL,<-4.913,0,0.7111>
    SPH1 =FEAT/SPHERE,CARTESIAN,OUT
    THEO/<-4.66,0,0>,<0,-1,0>,1.12
    ACTL/<-4.6624,0.0011,0.0007>,<0,-1,0>,1.1167
    MEAS/SPHERE,9
    HIT/BASIC,NORMAL,<-4.8976,-0.0005,0.5057>,<-0.4213219,-0.0025742,0.9069075>,<-4.8981,-0.0005,0.5069>,USE THEO=YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-4.9736,-0.1655,0.4319>,<-0.5575482,-0.2979988,0.774814>,<-4.9742,-0.1657,0.4327>,USE THEO=YES
    MOVE/POINT,NORMAL,<-5.1685,-0.1779,0.521>
    MOVE/POINT,NORMAL,<-5.1695,-0.1782,0.3803>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-5.0938,-0.1664,0.3116>,<-0.7726911,-0.2997621,0.5595455>,<-5.0943,-0.1666,0.3123>,USE THEO=YES
    MOVE/POINT,NORMAL,<-5.2158,-0.1784,0.4058>
    MOVE/POINT,NORMAL,<-5.2172,-0.0529,0.3173>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-5.1324,-0.0492,0.2963>,<-0.8419464,-0.0897712,0.5320407>,<-5.133,-0.0493,0.2968>,USE THEO=YES
    MOVE/POINT,NORMAL,<-5.2642,-0.1751,0.2149>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-5.1566,-0.1632,0.2004>,<-0.8852363,-0.2940349,0.3604167>,<-5.157,-0.1633,0.2008>,USE THEO=YES
    MOVE/POINT,NORMAL,<-5.2993,-0.1753,0.2152>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-5.1527,-0.1644,-0.2107>,<-0.87817,-0.2960073,-0.3757621>,<-5.1522,-0.1642,-0.2105>,USE THEO=YES
    MOVE/POINT,NORMAL,<-5.2643,-0.1763,-0.2249>
    MOVE/POINT,NORMAL,<-5.187,-0.0718,-0.4076>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-5.1263,-0.0667,-0.3043>,<-0.8307943,-0.1211562,-0.5432329>,<-5.1256,-0.0667,-0.3035>,USE THEO=YES
    MOVE/POINT,NORMAL,<-5.1927,-0.0723,-0.58>
    MOVE/POINT,NORMAL,<-4.9605,-0.045,-0.5816>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-4.9407,-0.0419,-0.483>,<-0.4986324,-0.0766973,-0.8634137>,<-4.9402,-0.0418,-0.4817>,USE THEO=YES
    MOVE/POINT,NORMAL,<-4.9606,-0.0451,-0.5941>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-4.9381,-0.1463,-0.4636>,<-0.4939856,-0.2637215,-0.8285102>,<-4.9376,-0.1459,-0.4623>,USE THEO=YES
    MOVE/POINT,NORMAL,<-4.958,-0.1569,-0.5987>
    ENDMEAS/
    COMMENT/REPT,
    # 52, 61, 62 & COMMON CENTERLINES
    DIM LOC11= POSITION OF SPHERE SPH1 UNITS=IN ,$
    X -4.6600 -1.5557 3.1043
    Y 0.0000 -0.7027 -0.7027
    Z 0.0000 -2.0067 -2.0067
    DF 1.1200 0.0200 0.0200 0.0167 1.1167 -0.0033 0.0000 ---#-----
    TP LMC 0.0100 0.0188 7.5252 7.5252 7.4964 -------->
    END OF DIMENSION LOC11
    MOVE/POINT,NORMAL,<-4.9535,-0.9761,-0.5964>
    MOVE/POINT,NORMAL,<-4.8723,-0.9418,11.6977>
    TIP/T1A7.5B90, SHANKIJK=-0.124, 0.0021, 0.9923, ANGLE=90.3292
    MOVE/POINT,NORMAL,<-4.1041,-6.7523,5.9501>
    WORKPLANE/XMINUS
    MOVE/POINT,NORMAL,<-4.6512,1.7226,5.9293>
    MOVE/POINT,NORMAL,<-4.6861,1.4197,0.4364>
    MOVE/POINT,NORMAL,<-4.1776,0.4548,0.0049>
    PNT2 =FEAT/POINT,CARTESIAN
    THEO/<-3.94,0.4558,0.0036>,<-1,0,0>
    ACTL/<-3.9432,0.4557,0.0038>,<-1,0,0>
    HIT/BASIC,NORMAL,<-3.9438,0.4558,0.0036>,<-1,0,0>,<-3.9432,0.4557,0.0038>,USE THEO=YES
    ENDMEAS/
    COMMENT/REPT,
    # 38 (2 OF 2 PLACES)
    DIM LOC12= LOCATION OF POINT PNT2 UNITS=IN ,$
    X -3.9400 0.0000 0.0050 -3.9432 -0.0032 0.0000 ---#-----
    END OF DIMENSION LOC12
    MOVE/POINT,NORMAL,<-6.0027,0.8133,3.0914>
    TIP/T1A90B90, SHANKIJK=-0.9999, -0.01, 0.0035, ANGLE=90.1188
    MOVE/POINT,NORMAL,<-0.9295,0.8857,8.829>
    MOVE/POINT,NORMAL,<-3.1759,-2.2056,4.1821>
    MOVE/POINT,NORMAL,<-3.6364,-0.9063,-0.0462>
    CIR8 =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR
    THEO/<-3.6462,0,0>,<-1,0,0>,1.2,0
    ACTL/<-3.6462,0.0008,-0.0012>,<-1,0,0>,1.1932,0
    MEAS/CIRCLE,3,XMINUS
    HIT/BASIC,NORMAL,<-3.6392,-0.5944,-0.044>,<0,-0.9974169,-0.0718301>,<-3.6392,-0.5943,-0.044>,USE THEO=YES
    MOVE/POINT,NORMAL,<-3.6374,-0.8023,-0.0465>
    MOVE/POINT,NORMAL,<-3.6399,-0.8037,-0.7567>
    MOVE/POINT,NORMAL,<-3.6478,-0.023,-0.7583>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-3.6474,-0.0213,-0.5973>,<0,-0.0367393,-0.9993249>,<-3.6474,-0.0214,-0.5973>,USE THEO=YES
    MOVE/POINT,NORMAL,<-3.6478,-0.023,-0.7832>
    MOVE/POINT,NORMAL,<-3.658,0.9872,-0.7852>
    MOVE/POINT,NORMAL,<-3.6556,0.9886,-0.0993>
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,<-3.652,0.5901,-0.0926>,<0,0.9881776,-0.1533133>,<-3.6518,0.5903,-0.0928>,USE THEO=YES
    ENDMEAS/
    COMMENT/REPT,
    # 50 & 51
    DIM LOC13= POSITION OF CIRCLE CIR8 UNITS=IN ,$
    Y 0.0000 0.0008 0.0008
    Z 0.0000 -0.0012 -0.0012
    DF 1.2000 0.0100 0.0100 0.0168 1.1932 -0.0068 0.0000 -#-------
    TP MMC 0.0100 0.0179 0.0028 0.0028 0.0000 #--------
    END OF DIMENSION LOC13
    PC-DMIS is a very dynamic software package with a LOT going on behind the scenes of the visible code. I see this sometimes if the theoretical values of the alignment features aren't correct, usually with older programs that were poorly/hastily written. For the past number of years I painstakingly make sure that ALL the theoretical locations and vectors are perfect. CAD helps, but if not I correct it by hand.
    Sometimes making a new position dimension will fix it. Sometimes making a new feature and then dimensioning it will fix it.
    PC-DMIS 2016.0 SP8
    Jeff
      To make the code easily readable...
      ANGLE VEC=<0,-1,0>
      DIRECTION=CCW
      ENDMEAS/
      ANGLE VEC=<0,-1,0>
      DIRECTION=CCW
      ENDMEAS/
      COMMENT/REPT,
      COMMENT/REPT,
      ENDMEAS/
      COMMENT/REPT,
      [B]SPH1 =FEAT/SPHERE,CARTESIAN,OUT
      ACTL/<-4.6624,0.0011,0.0007>,<0,-1,0>,1.1167[/B]
      MEAS/SPHERE,9
      ENDMEAS/
      COMMENT/REPT,
      [B]DIM LOC11= POSITION OF SPHERE SPH1 UNITS=IN ,$
      END OF DIMENSION LOC11[/B]
      WORKPLANE/XMINUS
      ENDMEAS/
      COMMENT/REPT,
      ENDMEAS/
      COMMENT/REPT,
      # 50 & 51
        I would try ASSIGN/V1=SQRT(DOT(SPH1.XYZ-SPH1.TXYZ,SPH1.XYZ-SPH1.TXYZ)) to check the deviation.
        In addition, you shoudn't use the same vector in circles for angle vector and surface vector...
