What Matt Said is a workaround if your CMM is down and you need to keep working anyway b/c you are not on ********'s payroll, but. . .
You can open a program online, and then open a second program offline and then use the dropdown Window menu to switch between them. (File>Open>Interface [bottom box/dropdown line])
And. . .
You can choose offline when opening the first program in pc-dmis instead of online.
When I was learning pc-dmis I was advised to run new unfamiliar programs offline first to "see" in the graphics screen what the program was going to do before executing the program online. Not all of those programs had good setup instructions, so this was helpful, especially in determining where the manual hits should be taken.
HTH
does anyone know how to program offline on a computer that is hooked up to a cmm? I started the program on an offline computer but we have two programmers...
I get interupted a lot to check production parts while programming offline and we only have one seat for PC-DMIS. Once I exit the program I'm working...
I use offline programming primarily and whenever I need to edit a program I move over to my offline seat. I usually run offline to re-set the program...
how do i run my program in a graphics mode without having to open it up as a second program executing it then closing both programs and then opening it...
