2021.1 sp1
  • 2021.1 sp1
    https://www.wilcoxassoc.com/public/P...021.1/SP1/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...021.1/SP1/x64/
    Release Notes - 2021.1 SP1
    Application Errors
    • PCD-209148 - You no longer get an application error when you click the
    Generate button on the Scan dialog box to re-generate hits after you edit
    a scan feature.
    • PCD-210119 - You no longer get an application error when you copy true
    position dimensions.
    • PCD-210133 - You no longer get an application error when you delete
    features that use the true position legacy dimensions.
    • PCD-210361 - You no longer get an application error when you open PCDMIS Online.
    • PCD-210366 - You no longer get an application error when the Romer
    interface fails to initialize.
    • PCD-210455 - You no longer get an application error when you switch
    from probe to scan.
    • PCD-210456 - You no longer get an application error when you select File
    | Close.
    • PCD-210466 - You no longer get an application error when you preview a
    pointcloud.
    • PCD-210587 - You no longer get an application error when you select File
    | Exit.
    • PCD-210593 - You no longer get an application error in a probe drawing
    area.
    • PCD-210681 - You no longer get an application error when PC-DMIS
    displays a license failure error message immediately after you open PCDMIS.
    • PCD-210719 - You no longer get an application error when you close a
    measurement routine with an active clearance plane.
    • PCD-210955 - You no longer get an application error when you drag and
    drop an item from the Summary mode to within or outside (such as
    custom report) the Summary mode.
    • PCD-210987 - You no longer get an application error when you calibrate
    probes.
    • PCD-211001 - You no longer get an application error at the end of the
    execution when you switch measurement routines.
    • PCD-211060 - You no longer get an application error when you calibrate
    tips.
    • PCD-211077 - You no longer get an application error when the device
    manager interface generates an error message before PC-DMIS is ready.
    • PCD-211122 - You no longer get an application error when you close a
    measurement routine.
    • PCD-211128 - You no longer get an application error when you perform
    an undo operation on an alignment.
    • PCD-211308 - You no longer get an application error when you carry
    tolerances forward.
    • PCD-211353 - You no longer get an application error when you close a
    measurement routine and then immediately open another measurement
    routine.
    • PCD-211969 - You no longer get an application error when the GD&T
    Selection option is not available in your license and you select the Pan,
    Zoom, Rotate tab in the CAD and Graphic Setup dialog box.
    Auto Features
    • PCD-185254 - You can now change the Row overlap value in the Auto
    Feature dialog box on directly measured Laser plane features.
    • PCD-210189 - You can now see the improved spectrum output for the
    Precitec CHRocodile S and CHRocodile SE controllers.
    • PCD-210200 - You can now see Re-measure works correctly when you use
    Rmeas on all contact features.
    • PCD-211612 - You can now see that, when in Offline mode and you
    measure an Auto Circle Contact with zero sample hits relative to a feature,
    PC-DMIS projects the circle onto the theoretical plane of the circle.
    CAD
    • PCD-210145 - You can now see all the CAD entities when you import a
    CAD file.
    • PCD-210872 - You can now see an improved import of CAD STEP files.
    CMM
    • PCD-163494 - PC-DMIS now saves the wrist speed in the registry settings.
    To do this, mark the Read machine defaults on startup check box for
    FDC controllers in the Machine Options dialog box.
    • PCD-211016 - You can now correctly calibrate multiple arms in the INCH
    mode when you use the AUTOCALIBRATE/MULTIPLEARM command.
    • PCD-211376 - PC-DMIS no longer converts the external command line
    from lowercase to uppercase.
    GD&T
    • PCD-208983 - PC-DMIS now allows 10 million hits for features in the
    Geometric Tolerance dialog box.
    • PCD-211223 - You can now see that FCF or Tolerance indicator with ISO
    behaves correctly for datums in the lower segment between Position and
    Line Profile or Surface profile.
    HxGN SFx | Asset Management
    • PCD-196206 - PC-DMIS no longer sends incorrect error events when you
    enable the Find Hole option for auto features.
    Laser
    • PCD-208943 - You can now execute thickness scan features with the
    Precitec 2SHS controller.
    • PCD-209468 - PC-DMIS now automatically performs a dark reference with
    a tool change to an HP-OW sensor.
    Probe
    • PCD-211073 - You can now show or hide the Probe Readouts window
    through automation.
    Protect
    • PCD-212003 - PC-DMIS now provides edit capabilities to authorized users
    to modify certified measurement routines created prior to the PC-DMIS
    2021.1.
    Q-DAS
    • PCD-210022 - You can now see the material condition information of
    K2020 in a part-specific Q-DAS data file.
    • PCD-210585 - You can now see the Max/Min profile reporting in a .dfq file
    for the Geometric Tolerance dimensions.
    Reporting
    • PCD-210875 - You can now see the correct ball color for leader lines
    drawn on the CAD reporting object in the custom report.
    Temperature Compensation
    • PCD-208280 - PC-DMIS Temp Comp V2 now lets you detect the mismatch
    in the compensation method and apply the correct method for the actual
    CMM for these two conditions:
    • H3C/FDC/CC controller
    • Measurement routines created with Temp Comp V1 that use
    the "Read Temperatures" method
    Thanks JEFMAN !
    I like the new, sectioned style.
    PC-DMIS CAD++ 2o19 R1 SP11
