Cmm Controller
  • Cmm Controller
    Hello Out There. Wondering If Anyone Can Help Me. I Am Running Pc Dmis V3.7 Using A Dea Tu01 Controller.
    I Was Wondering If There Was Any To Map Some Buttons That Aren't Used To Something I Want. F1 And F2 Buttons.
    Cause I Would Like To Have A Move Pt Button On The Controller. Just Move The Probe To A Certain Position And Hit A Button To Map It There In The Program, Instead Of Going Through The Other Way(insert, Operatin, Move Pt)
    Any Help Would Be Very Helpful
    Should be the crosshair looking button on the jogbox. I am not sure where to set that in the software since I still have 3.2, but it was in the Options/CMM Interface Set-up/Button Assignments
    Kevin
      ctrl+m
      if you are using 3.2 --> Options/CMM Interface Set-up/Button Assignments
      Higher than 3.2 ==> Edit-Preferences-Machine Interface Setup
      BUT , you may assign only one command for "cross hair button" either DONE or MOVE PNT
      Instead of going through the other way [insert, Operatin, Move Pt] Shortkey is CTRL + M
      Either seem as you are or be as you seem.M.J.Rumi
        Saliha,
        Can you assign any commands to the F1 and/or F2 buttons on the jogbox? I am not aware of if this is possible or how to do it.
        Kevin
          Hello. Actually Ive Been In The Edit/preference/ Machine Interface Set Up A Couple Of Times; And I Don't See Where I Could Access The Command To Change The Cross Hair Button Command. Because As It Stands The Cross Hair Should Already Be Programmed To Be Move Pt But It Does Nothing.
          The Options I Get When Going To Above Are:
          Controller-com Port, Type, Settings-baud.parity.data Bits.stop Bits
          So I Really Dont Know
            In your CMM interface window, there should be a tab marked DEA. It should be in the upper right hand corner of this window. "Button Assignments"
            Kevin
              THANKS, I FINALLY FOUND IT. ITS AMAZING HOW MANY TIMES YOU CAN LOOK AT SOMETHING AND NOT SEE IT.
              MANY THANKS TO YOU.
              YOU MUST BE A CMM GOD.
                MANY THANKS TO YOU.
                Not me, you must be thinking of Matt or one of the other guru's.
                Kevin
                  Saliha,
                  Hello Kmcmm ; as far as I know , it is not possible
