Updating Report Window while running
  • Updating Report Window while running
    Hi,
    When I'm running the CMM program the report windows is not updating. Report windows appear empty at the end of the program. Is there any command for update report windows while running?
    Thanks!
    It should populate as the dimensions are executed in the program. I put all of my dimensions at the end of each program, so the report is not populated until the very end of every run. Double-check that the dimensions are marked for execution, and if they are the next thing to look at would be the ouput. Make sure for each dimension that OUTPUT=BOTH or OUTPUT=REPORT. If OUTPUT=OFF, or if OUTPUT=STATS, it will not show that dimension in the Report Window.
      Make sure "Update Report During Execution" is ticked in the F5 Setup Options window. It's toward the bottom of the list.
      PC-DMIS 2016.0 SP8
      Jeff
