1:10 Taper
  • 1:10 Taper
    How can I dimension this? I am assuming that for every 1 unit in Y I should have 10 units in X?
    Is this correct?
    The overall height is 3.250" so for 3.250 in Y I should be .3250 in X which would be a 5.711° half angle?
    A quick Goooooooooooogle search:
    "The taper is the inclusive angle. Tapering of the propeller shaft. All propellers in stock at TechProMax have the standard taper 1:10. This means that the difference between the largest and the smallest diameter of the tapered hole represents 10% of the length of the propeller's boss (D-d=0.1 x L)."
      Okay. Good. So a 1:10 taper of a Ø2.8500 that is 3.2500 in length should have be D=2.8500 and a d=Ø2.525
      2.850 - 2.525 = .1 x 3.250 which is true
      I have been given the numbers length 3.250, Ø2.850, Ø2.525, and 1:10 taper. I was just verifying because it is an internal drawing. (which is not something we do often)
      So for inspection of the taper I guess I will just check the large diameter and the small diameter and maybe a reference angle of the cone.
        Sounds like the route I would go.
          What is the tolerance, e.g. how is it dimensioned? The 1:10 just defines the taper ratio, but where is the tolerance?
          PC-DMIS 2016.0 SP8
          Jeff
            There is no tolerance on the taper. Only on the top diameter. The small diameter is called as a reference.
            • LaserJay
              LaserJay commented
              ukcmm . . .
            • Mike Ruff
              Mike Ruff commented
              One time I got a literal napkin drawing with a Ø1/5in hole and a 8/32 hole. It was by far THE WORST "drawing" I had ever seen. I had to call the dude and confirm he wanted a Ø.200 hole and a 1/4" hole. When I talked to him, he said "eight thirty-seconds" and I said, "So a 1/4 inch?" and he said "No, an eight thirty-seconds screw hole." "So you want an 8-32 threaded hole?" "Uuhhh, yeah, I guess so." This came from an engineer at a very large and legitimate aerospace company too... There was also no language barrier, he just knew absolutely nothing. I couldn't believe it
            • LaserJay
              LaserJay commented
              Mike Ruff thats incredible lol
          • QS920
            Diameter angle intersect
            by QS920
            Good morning all,
            I'm having some sort of brain malfunction on how to measure this diameter to the intersection length.
            I did a search...
            02-07-2020, 08:58 AM
          • Sammus761
            Cone help
            by Sammus761
            With the notable exception of cone angle, I am having problems achieving believable results in obtaining measurements as shown in the attachment. These...
            03-08-2016, 08:52 AM
          • Underspec
            v4.2 Angle on Cones
            by Underspec
            We previously had v4.1 on our machine here and upgrade to v4.2. I'm using an autocone to measure a chamfer then dimension the plane intersect diameter...
            12-05-2007, 12:30 AM
          • MustHaveBeenBlue
            Taper
            by MustHaveBeenBlue
            hey guys, i'm trying to figure out a taper so i check my inside dia with a cone and want it to readout taper. how can i do this? or do you need more information...
            08-10-2009, 03:14 PM
          • JenWasch
            Conical taper
            by JenWasch
            I have a 1.5" +/-.0005 tapered cone I am measuring. The cone measures within tolerance.
            The next callout is .0625:1 taper. How is that dimension...
            12-11-2015, 07:20 AM
