Probe rotation
  • Probe rotation
    Is there a way to make sure that the probe makes the shortest rotation possible? If I command the probe to rotate to A90B-90 and I am at A90B-60 the probe naturally rotates 330 degrees as opposed to the 30 degree rotation. I'm running PC-DMIS 2013 MR1.
    *EDIT- My example was a poor choice. A better example would be rotating from A90B-182.5 to A90B182.5
    I don't think so.
      Are you sure you got that right? if it's rotating 330 degrees. something is wrong, What knuckle do you have? Rotation to the left in B 0 to -180 and to the right 0 to180. Pretty sure the only knuckle that rotates endless is Renishaws Revo
      • J_Tdmis
        J_Tdmis commented
        Renishaw PH10MQ. I was just curious if we could select shortest possible rotation. If not, then that feature should be added.
      • Matthew D. Hoedeman
        Matthew D. Hoedeman commented
        PH10 won't do that, it can't do that, it won't rotate around, only -180 to +180, it is impossible for the PH10 to rotate around past -180 to come back to -60.
      No not really, just have to be methodical as you write your program. Just like what you're trying to accomplish, I always use angles where I swing the probe/rotate my wrist the least amount as I possibly can. Less angles/movement = less wear & tear on the hardware & greater overall accuracy
        I see said the blind man. My probe is mechanically limited and cannot execute a rotation passed the 180 degree mark. Thanks for the help everyone.
        • CGoode
          Probe rotation
          by CGoode
          I have aligned a part with probe position A0B0. After aligning I rotate the probe to A90B(anything). Upon rotating the probe my alignment is not correct...
          05-17-2006, 02:33 PM
        • mitkos
          Shortcuts for probe rotation
          by mitkos
          Hi.
          I would like to create a shortcut for rotating my probe head to A0B0 (and maybe some other rotation A90B+/-90) and put it on my toolbar...
          09-05-2016, 07:23 AM
        • myrex11
          Probe Rotation Reference
          by myrex11
          Does anyone have a handy chart or cheat sheet that shows the probe angle rotation on a PH10? I know down is zero and right is 90 etc..just thought a reference...
          02-19-2013, 03:13 PM
        • cesarhart
          Probe rotation
          by cesarhart
          I currently run 4.3 version of PC Dmis and whenever I choose a probe rotation angle it does not execute.The probe does not want to rotate at all and that...
          06-23-2009, 07:20 PM
        • QE161
          skipping over probe rotations
          by QE161
          I'm looking for some help with avoiding probe rotations.
          I am going through some programs and using If_GoTo commands to skip over some...
          05-11-2009, 12:45 PM
