2020R2 Geometric Tolerance: Analysis Window Unequal Tolerance Band
  • 2020R2 Geometric Tolerance: Analysis Window Unequal Tolerance Band
    The analysis window on an unequal tolerance ASME profile doesn't show an unequal tolerance. The tolerance band looks pretty equal to me.
    After further review, this is a major change in the software, which I don't agree. I want to see the unequal tolerance zone.
    Yeah profiles are output differently in 2020 R2 than previous versions due to the way profiles are evaluated in the new ASME Y14.5 spec.
    https://www.hexagonmi.com/about-us/e...o-deal-with-it
    This video explains it well. Even though it's different you should still get the same results.
      I understand that, however the tolerance band in the graphical analysis should still show the unequal band widths.
      • MetsoMetrology
        MetsoMetrology commented
        I agree, but unfortunately no
      When you're using unequal, the software is still evaluating correctly. You'll get the correct number output. But for some reason they show the tolerance bands on "analysisview"-s as bilateral ONLY. No option to display as unequal. This confuses the old guys at my shop & is (in our opinion) an area for improvement
      • MetsoMetrology
        Yeah it's not intuitive at all
      MetsoMetrology PC DMIS is pretty behind other software when it comes to graphical analysis stuff. QUINDOS is FAR superior in that regard.
        Rob Jensen Can we get the unequal tolerance zones back in graphical analysis? This is confusing as now I needed to explain to the operators and management why it's different than what they have been used to for the last several years.
          I haven't used that modifier in a couple of years. But I have had to in the past and remember having good "anslysisview"-s in like 2017 or 2018.
          Why would they get rid of that capability? Huge step backwards.
            bfire85
            https://hexagonmi.userecho.com/en/co...s-view-command
            For you
              I used my last "like" on you. I was holding onto it for a suggestion worth it! You won!
                Thanks!
                The PCD forum gives you unlimited likes! =P
                  Originally posted by DAN_M View Post
                  Thanks!
                  Yes, however the suggest features only gives you 10. I may have to unlike something in order to gain more likes.
                    I know I was just messing with you while making a post to shamelessly boost my comment count
                      I understand the reason behind this change. As with the (U) or UZ modifier the middle of the tolerance zone is not equal with the nominal of the part.
                      The calculation for the profile uses the worst deviation from the middle of the zone (worst x2).
                      But I agree that is is much clearer how your part looks when you actually have an unequal zone in the graphics. It helps everyone understand the graphic much better in my opinion.
                      Rob Jensen maybe an additional line for the nominal can be added? I think it would help understanding the graphics better.
                      unequal.png ​​​​​​​
                        Hopefully they come through with this one.
                          I think I already put something along these lines on the idea center a few months ago.
                          https://hexagonmi.userecho.com/en/co...is-improvement
                          • MetsoMetrology
                            Yeah you created that one after I posted pretty much this same thread last year after I updated lol
