PCDMIS Issue at launch
  • PCDMIS Issue at launch
    When PCDMIS 2019 R2 is launched, I cannot open, create files: basically can't do anything. I submitted a ticket 4 days ago, called Hexagon and they said "We are really busy and someone will get back to you." The machine being down is causing a lot of issues within the department / company.
    Any idea why this would be happening???
    what error messages are you seeing? Can post screen shots? Is it only that version? Windows year?
      Definitely will need more details.
        Is there a popup that shows, TCIP not connected or something like that? Maybe your machine is not communicating with your computer, That's the only time I ever seen where I couldn't open anything.
          Just guessing-- when everything in the File menu is gray out, that could mean PCDMIS and the CMM aren't connected. Check ethernet cables are plugged in and check your Network Connections to see if the CMM is connected. Maybe your PC ethernet port went bad.
            Call them. Be respectful but stern. Remind them that your SMA is current and you’re machine down and that this is unacceptable. The person on the phone will regurgitate their pre-prepared “customer service script” about how they are experiencing high call volumes and some [email protected] about covid and yaddayadda.. then an actual tech will call you back within a couple hrs. Squeaky wheel gets the grease.
              We have this happen periodically on one of our newer CMMs. Have to reboot the PC and controller both. Happens about twice a week.
              • Matthew D. Hoedeman
                Matthew D. Hoedeman commented
                Reboot the computer and the controller, BUT DO NOT open Pcdmis until the controller is done rebooting.
              Try starting PCDLRN.EXE directly. The shortcuts generated by the installation procedure starts the HexagonLauncher which in turn launches PCDLRN.EXE.
              PC-DMIS CAD++ 2o19 R1 SP11
                all good suggestions. and please brian_del update here how this turns out!
                  My personal experience with this over the last few days. I have found this to be the issue after installing the Windows Update KB5000805 and/or KB5000808 depending on the version of Windows 10. There is a bug that is introduced that causes an immediate BSOD when trying to print to certain printers. This same update has broken PCDMIS as well. Uninstalling the update does not fix the issue. Doing a system restore will. The same problems described as original poster. Cannot open any programs and no communication with the machine.
                  Doing a system restore yesterday fixed the problem. Came back in this morning and the problem had returned along with the said Windows update. Had to do another system restore that fixed the issue again. You will need to postpone Windows updates.
                  Again, this was the problem in my case.
