Clearance Plane
  • Clearance Plane
    Hello All
    Someone suggested to me that it was better to use move points than to use the clearance plane feature. Can anyone tell me why it would not be better to use a clearance plane when working in the X-Y or any other working plane? Thanks
    It depends
    It depends on what your part looks lie. In general, clearance planes are much easier and less time consuming to program, but they consume precious time during execution when some people are trying to squeeze seconds out of every program execution.
      Used clearance planes when i first started. I now use nothing but move points. Less thinking involved on what the CP is gonna do when you start getting into different probe rotations............x plus, y minus...ect
        I use clear planes for repetitive features like bolt patterns. The rest of the time I use movepoints.
        It's all preference. Any one that tells you that one is an absolute must over the other should be deported.
          I use clearance planes at the beginning and end of the program, something that will 100% clear the part/fixture. I use move points (and SOME clearance planes) in the body of the program.
            I use clear plane 90% of the time. I find it easier if I have to remove a feature
            then I don't have to edit move points. I Never use the pass thru plane with clear plane
              Yep me too, another good useage. Any other useages will cost you your citizenship though.
                Ya better be nice or I'll put that picture back up!
                  What T Miller said. Except I use pass thru all the time. I also intermingle movepoints with clearplane stuff if I have a weird situation.
                  See...
                  THIS
                  ...for some extra information
                    I'm sure it'll only serve to sell more gumballs so go ahead. I could use the "bussiness".
                      I often use a combination of both clear planes and automoves (before and after) to compensate for different probe angles. You do have to make sure your PH10 will clear the part and/or fixture when rotated at A90B90 etc...
                      Kevin
                        I use move points at start / end of program and combination through out depending on amount of time clearance plane will take to get to next feature to be measured.
                        B & S XCEL 7-10-7
                        Sharpe32 Controller
                        PH10MQ & ACR1 Toolchanger
                        TP20 & TP2 Probes
                        Pcdmis CAD++ 3.7mr3, 4.3mr1, 2009mr1, 2010mr1
                        Datapage RT 3.33
                          I use both, but prefer move/point. I also use move/increment at times.
                          I can't get deported for a preference, can I??
                            I use move/clearplane with pass thru plane stated or move/increment. I never use move points. I think they are lazy and sloppy. I like my programs to run fast and they run slower with move points. Clearplane moves are at full speed. I feel much more confident editing a program with good clearplanes. Yeah they take more thinking, but that's where I make my bread, not with my back.
                            g
                              Same here, never ever used pass through plane
                              If I have offended anyone with this post, I'd like to take this opportunity to say BOLLOCKS
                              Dry your eyes Princess and man up.
