Doing an iterative alignment and I get a Out of tolerance zone =10. I'm using a fixture alignment along with theoritical point locations. Is there a way to adjust this tolerance zone?
Outside tolerance zone
Change the "PNT TARGET RAD" and "FIXTURE TOL" to whatever you want it to be and what your part can be acceptable to based the part's tolerances.
A1 =ALIGNMENT/START,RECALL:AUTO, LIST= YES
ALIGNMENT/ITERATE
PNT TARGET RAD = 5, START LABEL = , FIXTURE TOL = 0, ERROR LABEL =
MEAS ALL FEAT = NO ,MAX ITERATIONS = 99 ,LEVEL AXIS=ZAXIS ,ROTATE AXIS=YAXIS ,ORIGIN AXIS=XAXIS
LEVEL = PNT10,PNT11,PNT12,,
ROTATE = SM_RAD3,SM_RAD2,,
ORIGIN = PNT4,,
ALIGNMENT/ENDXcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Hi All
I am trying to align a fixture, using iterative alignment. I have done this 100's of times with no problems....-
04-18-2006, 01:47 PM -
by zoranIs there any way that I can see the codes for iterative alignemnt ( all the calculation that software does for that process)? Thanks,
06-15-2007, 08:26 AM -
by TCeckelsAnother question on fixtures....I know someone out there besides me has to be accountable for annual fixture calibrations......
For example:...-
02-16-2009, 01:47 PM -
by dwadeI have searched this morning and read through 20 or more threads and do not see what I need to know. I am having a hard time with a customer supplied...
02-03-2012, 06:15 AM -
by eavymetalWe have been using Point Target Radius in our iteritve alingment and I was wondering what should be used Point Target Radius and\or Fixture Tolerance....
06-30-2014, 07:33 PM -
