Feature Control Frame Settings
  • Feature Control Frame Settings
    Hello Everyone! Hey, I've got a question I can't supply too much information about - but thought I would try you Gurus. I have a print with a FCF location call out of:
    The Size;M; Then Datum's ABC; Then M again on C. The problem is there's no option in the drop down for the M on C. The M on size is there.
    Can anyone explain how the drop down options are controlled? Do I have an Engineer just plopping stuff in? I'm not strong yet on ASME rules and GEO TOL.
    Thanks in advance!
    Leitz Reference XI 10.7.6 with HP-S-XIH
    2017 R2 with SP3
    Datum feature C must be a feature of size to allow the use of a material modifier.
      What JacobCheverie wrote, doublecheck that your datum C is a feature of size, maybe it is a point or a line (now)?
      PC-DMIS CAD++ 2o19 R1 SP11
        It's an open ended slot. I measured a plane on each side, then added dimension the width. Is that not enough or how would I do it??
        2017 R2 with SP3
          So you are saying that you created a width out of those two planes. Which version are you using?
            Yes, that's correct. A width from 2 planes. Leitz Reference XI 10.7.6 with HP-S-XIH
            2017 R2 with SP3
            2017 R2 with SP3
              Jackarroo o Can you post the relevant sections of your code (datum feature creations, feature creations, dimension)? A width is a feature of size and should allow for the MMB modifier.
                Got it! I had only dimensioned the width call out characteristic. It wasn't enough. I constructed a width from the 2 planes. Worked perfectly! Thank you. J
                2017 R2 with SP3
