good morning i have a star tip that i need to put different size tips on it. is this possible. i need a 3x100 on the front and a 4x20 on the back. B&S global statur, PCDMIS 3.5 MR1, PH10T, TP20 extended force. thanks
star tip
ou can put different tips on, but a 3X100 is pushing it I believe. I have a 4x20 and two 2x20's on mine, but a 3x100 hanging out there is gonna have problems.sigpic
B&S Global 544
Using 3.7mr3
Peace
Greg
ONLY if you can remove the individual tips from the stap probe. Some of them do not allow you to take the individual tips out, some of them are made with permenant tips in them.sigpic
Originally posted by Kevin Watts View Postgood morning i have a star tip that i need to put different size tips on it. is this possible. i need a 3x100 on the front and a 4x20 on the back. B&S global statur, PCDMIS 3.5 MR1, PH10T, TP20 extended force. thankssigpic.....Its called golf because all the other 4 letter words were taken
Yes it is possible. You have to build it in your probe file. Use the EXTEN5WAY, TIP1 is pointing down, TIP2 points into XPLUS, TIP3 is Yplus, 4 is xminus, 5 is xminus.
As others mentioned, the size/weight can be an issue.When in doubt, post code. A second set of eyes might see something you missed.
can put different tips on, but a 3X100 is pushing it I believe. I have a 4x20 and two 2x20's on mine, but a 3x100 hanging out there is gonna have problems.Dale
v2011 MR1 CAD ++
Originally posted by WScmm View PostThis will give you problems. I am not sure about the TP20, but on my TP200 I was told to only have 100mm carbon fiber or 50mm steel hanging out there. I had to replace my TP200 because of this. I have a SP600 so I used it.sigpic.....Its called golf because all the other 4 letter words were taken
You had to replace the tp200 because of the length or it did something to it ????????????Dale
v2011 MR1 CAD ++
Originally posted by WScmm View PostI over weighted it. I haven't used a star tip before and I only needed 3 tips, but I put 5 tips on because I didn't know how to calibrate w/out them. (oh, the good old days). Now I use my sp600 for all star probes and I only use it w/ 3 tips. You will know when you do it. Your numbers get all messed up. I couldn't measure anything. I hadn't crashed it so I know it was something w/ the star probe. I just thought it was my calibration and I called Renishaw and they told me way to much weight. Chalked that one up to experience.
Thanks.......did not know you could do that.........good repsigpic.....Its called golf because all the other 4 letter words were taken
by illinoismikeI'm trying for the first time to set up a star probe and running into difficulties. The closest tips on the tip list are 3MMby33.5 and 3MMby 35 tips....
07-06-2010, 04:40 PM -
by NfiskI am trying to build a custom star probe for a part I need to measure. I have the EXTEN5WAY_TESA screwed directally into the TP20 with tips 2,3,4,&5...
06-26-2008, 11:31 AM -
by orionI created a star probe which I calibrated at A90B180 and A0B0 for all 5 tips. I
1 A90B180 & A0B0 ... All the way through to tip 5 but tip 5...-
02-27-2013, 05:15 PM -
by MikielivesI have placed a star tip on our Gage 200 CMM with Pc-Dmis version 2.3 software, this is a manual machine. I have the probe and tip described in the utilities...
10-19-2009, 04:42 PM -
by NfiskI am useing the star probe to measure a round part and I need tips 2-5 to measure the entire diameter. When it changes from tip 4 to tip 3 it asks for...
04-24-2008, 12:12 PM -
